RAID1 to single disk
Hi
I'm interested in removing a disk from a two-disk RAID1. But I want the system not to be with the raid failure notice.
I want it to become a single-disk RAID1 volume.
Can it be done?
I think the key is to edit the /mnt/HDA_ROOT/.config/raid.conf file (or /etc/config/raid.conf). I don't want to edit it without being sure
Thanks and regards from Spain.
Can it be done?
- MrVideo
Re: RAID1 to single disk
Nope, no can do. Why would you want to? If your single HDD fails, you've lost it all.
QTS MANUALS
Entware
Entware
HiMrVideo wrote:Nope, no can do. Why would you want to? If your single HDD fails, you've lost it all.
If I want to change/upgrade one disk that contains system to a bigger disk.
For example: initial TS219 with one 2TB disk and final TS219 with one 6TB disk.
Mi idea is introduce the 6TB, build a raid1, extract the 2TB disk, “downgrade” the raid1 to single disk and expand the volume from 2 to 6 TB
Un saludo
Agur eta ondo ibili
- OneCD
This part isn't supported by QTS. So, it's not possible to "downgrade" an array.
- MrVideo
Both HDDs must be replaced with the replace one-by-one option (in the manual).
QTS MANUALS
Entware
Entware
No, the idea is begining with one drive, build raid1 with a second drive, retire the first drive and “dowgrade” raid1 to single drive (the second).MrVideo wrote:Both HDDs must be replaced with the replace one-by-one option (in the manual).
I think that is possible with the correct edition of raid.conf
Un saludo
Agur eta ondo ibili
- MrVideo
That is not what your wrote in your original post.ganekogorta wrote: ↑Mon Sep 16, 2019 3:09 pmNo, the idea is begining with one drive, build raid1 with a second drive, retire the first drive and “dowgrade” raid1 to single drive (the second).
No it is not. QNAP does not support RAID sizes reductions. You go to RAID1, you gotta stay with it, or increase to RAID5 or RAID6.I think that is possible with the correct edition of raid.conf
QTS MANUALS
Entware
Entware
Hi
There is a solution that i wrote on qnapclub.es.
But it is in spanish (my language) . I hope that i’ll traslate it next weekend
https://www.qnapclub.es/showthread.php?tid=3139
I know that is unsupported by qnap but it’s a valid solution
- storageman
And you think this is something to recommend? Seriously???ganekogorta wrote: ↑Wed Oct 23, 2019 10:13 pm Hi
In case with two slots and one disk with problem, yes. Not everybody wants to use RAID1.storageman wrote:And you think this is something to recommend? Seriously???ganekogorta wrote: ↑Wed Oct 23, 2019 10:13 pm Hi
In case with a nas with two slots and you are using two single disks. When you want to change the system disk to a larger or new one... it’s useful
Un saludo
Agur eta ondo ibili
- storageman
Perhaps you could explain what is a system disk. What do you mean?ganekogorta wrote: ↑Wed Oct 23, 2019 10:53 pmIn case with two slots and one disk with problem, yes. Not everybody wants to use RAID1.storageman wrote:And you think this is something to recommend? Seriously???ganekogorta wrote: ↑Wed Oct 23, 2019 10:13 pm Hi
Un saludo
Agur eta ondo ibili
i want to say a system volume.
One disk with one Storage pool.
In the Storage pool there is volume (system)
Sorry,my english is terrible
In fact, there are 5 partitions in each disk. Our data is in the third partition.
Un saludo
Agur eta ondo ibili
Un saludo
Agur eta ondo ibili
I would be interested to see the translation - I think it should be posted with a warning for sure (stating high risk of data loss, backups must be made!), but this sort of stuff is useful nonetheless.
The QNAP structure is often too inflexible, and nobody wants to offer anything like this, but I think we should, even if only to discuss and say OMG, I lost everything etc!
Hi
I'll try to explain how to undo a raid 1 of TWO disks to ONE only.
It is even valid if it contains system volume. In fact this is the most interesting thing, especially for those who only have two bays in the QNAP.
This may be interesting for the following cases:
My Qnap is a TS469Pro with QTS 4.3.4
Just in case I recommend a data backup, as a failure can cost us to lose everything
Initially I have a disk in bay1 (the first) as a simple disk. It's size is 160GB and it's serial number is 5RX0XIJN
We examine and save the contents of the /etc/config/raid.conf file (which is actually located in /mnt/HDA_ROOT/.config/raid.conf)
Raid1 construction
Now we physically add in the second bay the "new" 160GB disk and serial number 5RX0XHMS.
The nas will let us know that it has detected it by beeping and will prepare the disc.
Remember that if that disk has something it will erase it without asking (as long as they are not previous QNAP partitions).
From the menus, migrate from single disk to RAID1
We finish the wizard and wait for both disks to be synchronized (be patience if you have large disks)
When it's finished we'll be with something similar to this
Now again we get the contents of the new /etc/config/raid.conf file
These values have changed:
chunkSize = 0
readAhead = 4096
dataBitmap = 3
And these are the new lines:
pd_5RX0XHMS_Raid_Bitmap = 0x2
data_1 = 2, 5RX0XHMS
scrubStatus = 1
eventSkipped = 0
eventCompleted = 1
degradedCnt = 0
Now go to the console and using the mdadm command you can see the status and other information of the raid.
Run "mdadm --query --detail /dev/md1" where md1 is the first (and only) raid1 created on the nas.
You see the correct size and status information for "clean". We also see in the lower lines the partitions involved in it.
On disk number 0 (bay 1) the partition is /dev/sda3
On disk number 1 (bay 2) the partition is the /dev/sdb3
Now we put the first disk into failure mode and extract the disk using two commands:
"mdadm /dev/md1 --fail /dev/sda3"
"mdadm /dev/md1 --remove /dev/sda3"
The nas will beep and activate the red alarm LED. Now we can physically extract the disk from the first bay (the original)
If we go to the QTS environment we'll see the following
We can also see it from the console with "mdadm --query --datail /dev/md1"
I run the following command by console to reduce the number of raid members to a single member. I get a single-disc Raid1
"mdadm --grow /dev/md1 --raid-devices=1 --force"
Now we need to edit the /etc/config/raid.conf file to look like this:
I've removed the lines that begin with "scrubstatus, eventskipped, eventcompleted,degradedcnt".
I've removed the line that starts with "data_0", and the one that starts with "data_1" I've modified it to "data_0 = 1, disk_serial_number"
I removed the lines from the [Remove] field
I've changed chunkSize from 64 to value 0
I've changed readAhead from 4096 to value 0
I've changed databitmap from 3 to value 1
We can be done faster if you take advantage of and edit the initial file (raid.conf) when there was a single disk, we would only have to update the serial number of the disk with the new one.
Once the change is saved, we turn off the nas via QTS or from the console with "halt".
When it's off, we move the disk from Bay 2 to Bay 1 and mission accomplished.
We started and we already have our new record with everything we had in the original.
If we go to the QTS environment we will see the following:
And if we do it by console
The disk that was in Bay 1 and we removed, contains EVERYTHING, nothing has been deleted.
If we want to use it on the nas again we must delete the five partitions.
I hope it will be useful for qnap nas owners with two bays who wants to change that disk.
P.D. If you see spelling errors, clemence with me
Regards from Spain
- I have a disk with SMART crash warnings, I buy one same size, expand to RAID1 and remove it by removing the "touched" disk
- I have a RAID1 and I want to undo it to reuse a disk because I need space or to mount it as a single drive.
- 1- We start from a single disk, create a raid1 and remove the old disk
[Global]
raidBitmap = 0x2
pd_5RX0XIJN_Raid_Bitmap = 0x2
[RAID_1]
uuid = adcdd09b:1286b132:793faae3:09f1257a
id = 1
partNo = 3
aggreMember = no
readonly = no
legacy = no
version2 = yes
deviceName = /dev/md1
raidLevel = 1
internal = 1
mdBitmap = 0
chunkSize = 64
readAhead = 0
stripeCacheSize = 0
speedLimitMax = 0
speedLimitMin = 0
data_0 = 1, 5RX0XIJN
dataBitmap = 1
[Global]
raidBitmap = 0x2
[RAID_1]
id = 1
partNo = 3
aggreMember = no
readonly = no
legacy = no
version2 = yes
raidLevel = 1
internal = 1
mdBitmap = 0
chunkSize = 0
readAhead = 4096
stripeCacheSize = 0
speedLimitMax = 0
speedLimitMin = 50000
dataBitmap = 3
scrubStatus = 1
eventSkipped = 0
eventCompleted = 1
degradedCnt = 0
chunkSize = 0
readAhead = 4096
dataBitmap = 3
scrubStatus = 1
eventSkipped = 0
eventCompleted = 1
degradedCnt = 0
[Global]
raidBitmap = 0x2
[RAID_1]
id = 1
partNo = 3
aggreMember = no
readonly = no
legacy = no
version2 = yes
raidLevel = 1
internal = 1
mdBitmap = 0
chunkSize = 64
readAhead = 0
stripeCacheSize = 0
speedLimitMax = 0
data_0 = 1, 5RX0XHMS
dataBitmap = 1
[Remove]
Regards from Spain
Great job done, THX!ganekogorta wrote: ↑Fri Nov 01, 2019 5:56 pmI'll try to explain how to undo a raid 1 of TWO disks to ONE only.
I'm de-RAIDing my 2-bay QNAP slightly different way, will share when successful finishing.
