Set this TS231P up as a newby (ans still one) with 2 WD Red 4TB drives.
Wanted them to add up to 8TB of space not as a mirror raid.
It shows both drives as Good with 3.64 TB and warning getting close to end as RAID Group 1.
Is this set up as a mirror ? How do I tell whether it is set up as 1 4TB drive with other not connected (so only giving me 4TB space) or as 1 primary and one mirror.?
Quite confused at this point.
I want to know if a backup is needed or if it is mirrored.
Does this take a model take a 6 or 8TB drive ?
TS231P 2 x 4TB WD drives - Showing 3.64 used. Warning
- Easy as a breeze
QNAP TS-231P 2 x 4TB Group 1 RAID 1
QNAP TS-451A 3 x 2 TB Group 1 RAID 5
Re: TS231P 2 x 4TB WD drives - Showing 3.64 used. Warning
without screenshots hard to say
remember that with raid0(adding the drives together) , you will lose all data on single drive failure..so remember backups (8TB drive if you want to use all of the volumes capacity)
- Easy as a breeze
Many thanks for your reply.
I have attached a couple of screenshots, hoping they are what you need to determine my disk status.
Would I need a 4 or an 8 for backup as it is now?
I am thinking of getting a 4 drive box (NOT NAS) as USB or LAN backup. I have one box for other things and I am very happy with it.
pool management screenshot would be most helpful
e.g. (my 951X)
e.g. (my 951X)
- Easy as a breeze
Sorry but it looks like I do not have a Storage Pool setup.
- Easy as a breeze
Do I need to have a Storage Pool?
At the moment I need to know if my set up is a (4TB) primary drive and a (4TB) mirror or 2 separate drives of which I only have access to one?
I want to know so I an arrange a backup and/or larger drives (8TB)
you dont need a pool .. static volume works fine
not sure where to check for raid type then in gui
you could do a
via ssh
you could do a
cat /proc/mdstat
- Easy as a breeze
Many thanks.
I think I did find it in the gui and here is the snapshot.
I guess it is set up as a RAID 1 with both disks used, one as a mirror. Am I correct ?
So how do I go about a back up or to go to a bigger disk size please?
no way back to non raid
so if you want to increase size, you either need to replace both drives (process explained in the manual) or destroy the raid and start from scratch
