Hi Friends,
I couldn’t mount my TS-412 anymore. Unfortunately I haven’t backup and will lost my all files since 20 years. Please advise me what I should do?
By mount:
[~] # mount /dev/md0 /share/MD0_DATA -t ext4
mount: wrong fs type, bad option, bad superblock on /dev/md0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
[~] # dmesg | tail
[6172968.126956] 65536 pages of RAM
[6172968.130194] 4592 free pages
[6172968.133167] 1637 reserved pages
[6172968.136501] 4655 slab pages
[6172968.139480] 9959 pages shared
[6172968.142628] 2143 pages swap cached
[6188630.038755] EXT3-fs (md0): error: couldn't mount because of unsupported optional features (240)
[6188660.526552] EXT4-fs (md0): ext4_check_descriptors: Checksum for group 1952 failed (2001!=21962)
[6188660.535489] EXT4-fs (md0): group descriptors corrupted!
[6189085.694828] EXT3-fs (md0): error: couldn't mount because of unsupported optional features (240)
By e2fsck
[~] # e2fsck -b 32768 /dev/md0
[/zhou01] # e2fsck -v /dev/md0
e2fsck 1.42.6 (21-Sep-2012)
/dev/md0 was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Inode 33161291 has INDEX_FL flag set on filesystem without htree support.
Inode 33161854 has INDEX_FL flag set on filesystem without htree support.
Inode 33817489 has INDEX_FL flag set on filesystem without htree support.
Inode 33817502 has an invalid extent
(logical block 1414924045, invalid physical block 18607859670, len 2338
(logical block 1414924045, invalid physical block 18607859670, len 23382) 2)
Killed
[~] # ./md_checker
Welcome to MD superblock checker (v1.4) - have a nice day~
Scanning system...
Legacy Firmware Detected!
Scanning disks...
RAID metadata found!
UUID: 8fef4a01:f9ad7ed3:f1c07847:3695fc40
Level: raid5
Devices: 4
Chunk Size: 64K
md Version: 00.90.00
Creation Time: Dec 5 05:40:56 2013
Status: ONLINE (md0) [UUUU]
Disk | Device | # | Status | Last Update Time | Events | Array State
1 /dev/sda3 0 active Apr 23 04:58:43 2020 0.1020264 aaaa
3 /dev/sdc3 1 active Apr 23 04:58:43 2020 0.1020264 aaaa
2 /dev/sdb3 2 active Apr 23 04:58:43 2020 0.1020264 aaaa
4 /dev/sdd3 3 active Apr 23 04:58:43 2020 0.1020264 aaaa
[~] # ./nasreport.sh
** QNAP NAS Report **
NAS Model: TS-412
Firmware: 4.3.3 Build 20190921
System Name: NASD8C4A6
Workgroup: NAS
Base Directory: /share/MD0_DATA
NAS IP address: 192.168.2.100
Default Gateway Device: eth1
inet addr:192.168.2.100 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:13654427 errors:0 dropped:4004 overruns:0 frame:0
TX packets:949288 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:1551473592 (1.4 GiB) TX bytes:168663320 (160.8 MiB)
Interrupt:15
DNS Nameserver(s):192.168.2.1
HDD Information:
Model=ST2000DM001-9YN164 , FwRev=CC4B , SerialNo= W1E244YA
Model=ST2000DM001-9YN164 , FwRev=CC4B , SerialNo= W1E21VVF
Model=ST2000DM008-2FR102 , FwRev=0001 , SerialNo= WFL1NLES
Model=ST2000DM001-9YN164 , FwRev=CC4B , SerialNo= W2F0MYMP
Disk Space:
Filesystem Size Used Available Use% Mounted on
/dev/ram 32.9M 17.2M 15.7M 52% /
tmpfs 32.0M 368.0k 31.6M 1% /tmp
/dev/sda4 371.0M 363.0M 8.0M 98% /mnt/ext
/dev/md9 509.5M 179.7M 329.7M 35% /mnt/HDA_ROOT
/dev/ram2 32.9M 419.0k 32.5M 1% /mnt/update
tmpfs 64.0M 2.4M 61.6M 4% /samba
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
Mount Status:
/proc on /proc type proc (rw)
none on /dev/pts type devpts (rw,gid=5,mode=620)
sysfs on /sys type sysfs (rw)
tmpfs on /tmp type tmpfs (rw,size=32M)
none on /proc/bus/usb type usbfs (rw)
/dev/sda4 on /mnt/ext type ext3 (rw)
/dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered)
/dev/ram2 on /mnt/update type ext2 (rw)
tmpfs on /samba type tmpfs (rw,size=64M)
tmpfs on /mnt/rf/nd type tmpfs (rw,size=1m)
none on /sys/kernel/config type configfs (rw)
RAID Status:
Personalities : [raid1] [linear] [raid0] [raid10] [raid6] [raid5] [raid4]
md0 : active raid5 sda3[0] sdd3[3] sdb3[2] sdc3[1]
5855836800 blocks level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md4 : active raid1 sdd2[4](S) sdc2[3](S) sdb2[2] sda2[0]
530128 blocks super 1.0 [2/2] [UU]
md13 : active raid1 sda4[0] sdc4[3] sdd4[2] sdb4[1]
458880 blocks [4/4] [UUUU]
bitmap: 0/57 pages [0KB], 4KB chunk
md9 : active raid1 sda1[0] sdc1[3] sdd1[2] sdb1[1]
530048 blocks [4/4] [UUUU]
bitmap: 0/65 pages [0KB], 4KB chunk
unused devices: <none>
Memory Information:
MemTotal: 255596 kB
MemFree: 41820 kB
NASReport completed on 2020-04-23 04:34:13 (./nasreport.sh)
Done.
Please help me!
zhou01
Help! RAID5 unmounted - I haven't backup:(
Re: Help! RAID5 unmounted - I haven't backup:(
did that happen by itself or did you have a power outage/lightning storm/etc ?
The raid5 itself looks ok, and this old CAT1 unit does not have any LVM structure on top of it
Thank you, dolbyman!
The status light was red and then I have hard stop it and start it again. Is there any chance to recovery all data?
- MrVideo
Open a support ticket with QNAP. Also, those Seagate DM HDDs are a problem waiting to happen. Best to replace those. Lastly, start doing external backups.
QTS MANUALS
Entware
Entware
- Moogle Stiltzkin
learned your lesson yet? gonna start backing up now?
Please read this
https://www.reddit.com/r/qnap/comments/ ... _a_backup/
i don't know how much storage you are using, but a wd elements or easystore external storage (whichever you can get cheapest on a deal) might be the way to go.
NAS
Network
Resources
Network
Resources
hi zhou01,
did you ever had a chance to get your raid 5 working again? I have the same problem - had a power outage and now my raid5 md0 can't be mounted - same failure messages?
tia bernhard
tia bernhard
