Creating SED secure storage pool failed
s4nd3r84
Post by s4nd3r84 »
Hi
I have 2x Samsung 970 Pro m.2 disk in my nas. Disk support SED option and is on the compatibility list.
When i create a new storage pool i select the SED option. After final summary it starts creating but then stops with error "Failed to create storage pool"
I dont understand why this is not working. I want my system / os disk encrypted with supported sed option but i cant make this work :(
Help is very appreciate
NAS Model: TS-h886 128GB Ram FW: h4.5.0.1409
OS: 2x M.2 NMVe Samsung 970 Pro 1TB Raid1
VM: 2x SSD Samsung 860 Pro 1TB Raid1
Data: 6x HDD Seagate Exos X16 16TB Raid5
QM2-2P-384: 2x Samsung 970 Pro 512GB Raid1 Cache
LAN-10G2T-X550: 2x 10 GbE
UPS: APC Back-UPS Pro 900
P3R
Re: Creating SED secure storage pool failed
Post by P3R »
s4nd3r84
Post by s4nd3r84 »
Have create a ticket and hope Qnap support will solve it :)
Skickat från min iPhone med Tapatalk
chodaboy19
Know my way around
Post by chodaboy19 »
Were they able to figure anything out?
TVS-672N h5.0.1.2248 build 20221215
i7-8700T | 64GB DDR4 (2 x M471A4G43MB1-CTD) | 2 x Samsung 970 Evo Plus 1.0TB | 6 x 18TB HGST HC550
interfaSys
Post by interfaSys »
I had this issue a few times. A reboot should solve it.
dcinca
Post by dcinca »
Updating the BIOS will fix this.
Open a ticket to get a beta BIOS if the newest one won't work.
Manu77
First post
Post by Manu77 »
I got the same issue with TS-h886 new ordered and 2x 1TB Samsung 980 PRO with heatsink nvme ssd. QuTS and QTS.
