hello,
I'm in a "no exit" situation with my nas
configuration is easy
3 disks RAID 5 + 1 disk (maybe my fault marked ad available and not spare - seems not important)
all 3Tb WD red
yesterday 1 disk was marked in a warning state (not defunct) - SMART paramaters over quota. suggest to replace disk.
should be a not dangerous situation
after this, using file sharing become almost impossible. minutes to copy a few Kb file and minutes to browse small directories
web interface nearly unusable. 5 minutes to log-in and more to see the main menu
logs not accessible - helpdesk not accessible
wasting a lot of time I've been able to reach storage pool page where the 3 disk are in use (one with warning - as already said).
immediate prompt to perform a file system check.
I've done and waited 18 hours ca.
at the end no errors but again the same prompt.
during that time nothing is possibile:
- no way to mark disk as defective
- no way to add the 4th disk as spare
- no way to execute any of the 'manage' commands
so, this seems to be an infinite loop with no exit and no action possible
the only thing I suppose possible is to shutdown nas, remove warning disk and hope that RAID survives let me a chance to add the spare disk
but I have to do this in a "not clean filesystem" state
any other idea?
thank you
p.
Weird RAID problem with no solution on my TS-453A
Re: Weird RAID problem with no solution on my TS-453A
no..the way it works it to hotswap the busted drive
you cannot modify a degraded raid..thats why all other options are greyed out
pull it out and replace it with a new one
you can always login via ssh and check the rebuild progress via
cat /proc/mdstat
immediately after disk removal, web interface has come back alivedolbyman wrote: ↑Fri Apr 09, 2021 10:25 pm you can always login via ssh and check the rebuild progress via
cat /proc/mdstat
it's friday afternoon, I've put rebuild as priority.
only doubt: even if rebuilding is asking me to perform a file check.
I suppose it's better to postpone at the end of rebuild
thank you so much!
