Migrating from TS-253 Pro to TS-453DU
dcabrerag
Post by dcabrerag » Thu Apr 22, 2021 11:50 pm
Hello everyone, please i need your kindly advice about migrating from TS-253 Pro to TS-453DU.
TS-253 Pro Disks
- x2 4TB RAID 1
Steps i've done already:
- Firmware Update to new NAS TS-453DU
- Install old hard drives (x2 4TB) to new NAS TS-453DU
- Migration completed and everything working ok.
Now, i have 4 new 10TB/each ironwolf hard drives meant to be installed on the 4 bays from the new NAS 453DU, replacing the old 4TB ones.
In this scenario is where i have a few questions:
- Whats the best procedure to migrate/upgrade/replace from the old x2 4tb Raid-1 to the x4 10tb ?
- Which RAID configuration will be the more safely to my final configuration (x4 10TB)?, considering final use is samba shared folders, qsync and backups; no VM's, no databases, etc. Raid6, Raid10?
- When rebuilding the 10tb drives, will the NAS services go down?, because evrything is LIVE right now.
I appreciate the help.
Thanks.
dolbyman
Re: Migrating from TS-253 Pro to TS-453DU
Post by dolbyman » Fri Apr 23, 2021 12:15 am
You can migrate to RAID5 and then optionally RAID6 (RAID10 is not a migration option from RAID1.. and also slower for given usage)
For a 4 bay unit, I would go with RAID5 (of course constant external backups are a MUST anyways)
During the disk swap, the NAS will be full available, but usage will slow down the migration (priority can be chosen in GUI)
dcabrerag
Post by dcabrerag » Fri Apr 23, 2021 4:31 am
Thanks for the response, rebuilding right now the first disk, everything smooth.
One last question, after disk swap/rebuild process is completed, there is a final step called Extend Storage from raid group, will this final process affect the NAS availability?
Thanks again.
dolbyman
Post by dolbyman » Fri Apr 23, 2021 4:42 am
Yes, depending if you have a storage pool or a static volume
Pool:
-Expand the Pool
-Expand the thin/thick Volume(s)
Static Volume:
- Expand the Volume
Both is explained in the manual :P
