Hello all, I hope all is well. I’m new around here but unfortunately I’ve been around long enough to have all my files QLocker’ed.
I am not good with all this setup stuff and only use this for a Plex server/backup for important files. My only drive(6tb) worked fine without any issues not including the QLocker issue. After losing everything, I decided to buy a new, larger Nas drive and then just use the old, 6tb as a snapshot/backup drive. Problem is that I installed the new 14tb drive and attached it to the original pool I currently use. It says 2 drives are attached but when I try to access it, it only shows 1 drive. I’ve tried detaching/reattaching it and also a few other things but it won’t show. Anyone have a similar problem?
I get this may be a stupid question, but I’m just lost when it comes to this stuff.
Thanks for any ideas you may have.
Allan
New drive is not accessible.
Re: New drive is not accessible.
if you pool both single drives together, you will only see them in one pool
also never backup internally
