How to turn Firmware auto update off?
spacesimon
Post by spacesimon »
Anyone know how to disable this new "feature" ?
I do keep on top of the updates but a specified time is a PITA.
Clients could be writing files through the night or just be busy and this creates disruption to all users.
Anyone worked it out?
syncthing
Know my way around
Re: How to turn Firmware auto update off?
Post by syncthing »
you should look into the control panel -> system -> firmware -> auto update
Moogle Stiltzkin
Contact:
Post by Moogle Stiltzkin »
that's simple. i did it already after reinitialize.
there is an option to disable the new default for auto firmware update.
however thkfully the new firmware notification is separate. that one i left enabled which i recommend.
NAS
Network
Resources
spacesimon
There are tick boxes for "latest" or recommended I know that.
I'm expecting a "disable" ?
Are the 2 tick boxes when unticked basically "off" ?
tia
Mousetick
Experience counts
Post by Mousetick »
spacesimon wrote: Sat May 01, 2021 1:32 am There are tick boxes for "latest" or recommended I know that.
Yes. If neither "latest" nor "recommended" are checked, then you get nothing.
raidforsaving
Easy as a breeze
Post by raidforsaving »
Mousetick wrote: Sat May 01, 2021 4:27 am
Thanks for posting this. Just updated to a new version and started reading about auto-update when I just happened to notice the subject elsewhere.
Model name: TS-653D
Firmware version: 4.5.3.1697 build 20210611
Volumes: EXT4, Encrypted volume
Previous: TS-651 dead by CPU bug
