TS-453A New disk replacement ++
Currently i have 4 * 2TB disks in a raid5 configuration and 1 now legacy volume on my 3 years old TS-453A, a setup upgraded, but unchanged, several times over the last 12 years since my first TS-419.
I have ordered 4 new 10tb WD Red Pro and plan to expand my nas. The question is: Can i just replace one by one and then create a new (more up to date) volume and then move my files from the legacy volume and then delete it ???
I am on firmware 4.3.6.
Re: TS-453A New disk replacement ++
no..legacy volumes have a 16TB limit ..you will have to start the volume from scratch
Hmmmm .... thank you dolbyman..
Was afraid of that ... but ok, i have backup on USB of files and settings - so can be done.
But .. I still have my old (very old) TS-419, wonder if i can mount the old disk there and then restore after creating the new volumes on my TS-453.....maybe
no ..you cant migrate back to the 419
see the migration guide for possible migration directions
Thank you again for your answers dolbyman
Somewhere in here i read, that systems who support storage pools do not have the 16TB limit ... as i understand does my 453A support that ??
correct...your NAS does not have that limitation
Then.... sorry to ask a lot but.. does that mean that my first suggestion .. replace disks one by one, create new volumes or storage pools, move data and then delete legacy volume, would be a valid way to go ?? ... or will my legacy volume stand in the way anyway ?
the system would have to be moved(hidden on the legacy volume).so a clean start is better
Hey again
Did a clean start with new disks today ........ What a f...king nightmare .... HBS 3 backup nearly no use, cannot restore because backup never run can only restore one folder by one ... container station cannot start because it cannot create interface "docker0" .....
Your backup never ran? Did you not check that beforehand ?
it ran ... i even did just before..
but i think its because i reset all ... then the HBS don't know, and then say "never run" .. but of course it did.
if it's a plain file backup, you can just copy from external to internal
or did you do versioned or dedup backups?
Thank You again dolbyman
I can see the files on my backup devises .. so its no problem .. i am restoring now.. had just hoped to do a restore in HBS and let that run until all back
