Degraded while reaplcement
hello,
im totally new in Qnap management; my brother was taking care of me before
I was trying to follow the instruction here https://www.qnap.com/en/how-to/tutorial ... ty-upgrade
however when I insert the new drive its starts stating Degraded not rebuild
what should I do?
what should I do?
Re: Degraded while reaplcement
nas model?
nas firmware?
what is the plan?
what did you do?
nas firmware?
what is the plan?
what did you do?
TVS-682 latest frame
im trying to replace the drive
always state build.."latest" is useless
you swapped the drive to increase capacity? because it was defective?
did you swap the drive hot?
im not familiar of what you state here sorry but I tried to follow the page instruction and I fail and now I'm stuck don't know what to do
what exaclty did you try to do? (swapping a drive with what goal?)
did you shut the nas down to swap the drive(bad) or did you swap the drive while it was running(good)
hello im was trying to do replace for drive using this guide https://www.qnap.com/en/how-to/tutorial ... ty-upgrade
my goal is to increase the capacity for drive because it was full
still no answer on how it was swapped
can you close the top window to see if the drives are in resync right now ?(it's covering that info)
ok sure this is another screen
and i swap it was Qnap on as per guide
i have even insert another 12 TB drive in Disk1 to try rebuild still not working!
you could just answer my question instead of repeating " as per guide"
that extra drive was added as spare
best to open a ticket with qnap ..something went wrong
no its not spare and even i make it free and still not working
I have ticket since morning with no luck and I even had teamview session
I'm sorry I'm not trying to repeat but as I said I'm new in this issue so sometime I don't know what your asking I'm so sorry if you felt I'm trying to repeat
if you can help me in any means I appreciated it !
one thing i have noticed when i added extra drive its free and when I select rebuild on it its just give nothing and change it from free to be spare!
is that normal?
because nothing working
is that normal?
I already asked several times if you swapped the drive while the nas was on or off ..not a technical question ..very easy to answer
so you already have a ticket open and qnap connected via TeamViewer...what was done there ?
