A hard drive that was formatted on a different qnap was put into "replace disks one by one" to go from a 4tb disk to a 6tb disk, but there was a power outage during the same time. So I have 3 6TB drives in the raid 5 pool, but the total storage is stuck at 7tb rather than being growable.
The storage pool management and "expand storage pool" are attached.
Can't Grow RAID 5
Can't Grow RAID 5
Re: Can't Grow RAID 5
click on manage "replace one by one" and then next
when inserting drives make sure they have been cleared first ..drives with qnap signature are normally not synced into existing raids
