unable to access shared directories
scta_tom
First post
Post by scta_tom »
I am unable to access the shared drive through windows due to 100% full disk and was able to access the web file manager to free up space to resolve this in the past.
This time around I can't seem to access any directory, just fails to load. I've tried manually deleting folders from SSH but MD0_DATA doesn't list once you're in the directory, just no response.
Model #: TS-1279U
edit: you can disregard this post, thank you. The nmbd. process kept looping because the QNAP never rebooted from the power management request.
Best Regards,
Tom
dolbyman
Re: TS-1279U MD0_DATA
Post by dolbyman »
What is the actual issue ? .. did your fill up your volume 100% ?
The title does not help either
