Ports are closed or services are down.
How do I tell the difference ?
TS-873U-RP with SSH, web server, SMB all unreachable from multiple devices
The 2 IP addresses respond to pings and shows in ARP.
A port scan shows only port 3943
"999 closed ports" ... so probably not the services down ?
No physical access at the moment to eyeball LEDs.
Would QFinder help ?
What process should I take to regain access and minimize any log loss so we can perhaps figure out what happened ?
UPDATE - in case it helps someone else ! :
Turns out there was a 10-15 minute power interruption last night.
When someone could physically look at it, we saw:
- power ON solid
- status NOT lit (drives are in standby)
- ethernet blinking orange (connected to network but not being accessed)
- drives lit solid green (can be accessed but are not being accessed/no activity)
Pressed power button just long enough to turn off (1 second), waited 15 seconds, turned it back on, all came back online without issue.
- status LED went solid green (ready), ethernet went solid orange (being accessed), and drives started flickering with activity
I was disappointed that /var/log were all new data - only recorded it powering back on, but at least the GUI confirmed the power outage.
QNAP offline except one port 3943 NUT = it was only DORMANT/on standby
[ TS-873U-RP @HQ ][ TS-220 + TS-221 +TS-419 U II @Satellite branches ] [ TS-212P + HS453-DX @Home ]
Re: QNAP offline except one port 3943 NUT
Any suggestions as to what we have misconfigured such that it's not recovering from autoprotect mode ?
Re: QNAP offline except one port 3943 NUT = it was only DORMANT/on standby
I have never used that mode, but there has been confusion about it before
viewtopic.php?f=11&t=35889
viewtopic.php?t=90836
