BAD block SCAN - when running it?
abpitt
Post by abpitt »
hi boys, i'm new of this community.
i've received the message "Message: [Hardware Status] "Host: Disk 5": Medium error. Run a bad block scan on the drive. Replace the drive if the error persists".
can I run the process whith my VM started or it is necessary stopped them?
thanks for help.
838Joel
Easy as a breeze
Re: BAD block SCAN - when running it?
Post by 838Joel »
abpitt wrote:hi boys, i'm new of this community.
thanks for help.
No problem to run it "live". Just did on a drive in my array and was using the data on this array.
Maybe it's going to be slower depending how much you use it.
To give an idea, it took about 24h for a 16Tb drive.
Sent from my Pixel 3 XL using Tapatalk
abpitt
Post by abpitt »
great. i run it immediately. many thanks
