Hello!
I migrated a RAID1 setup into a new QNAP TS-253D. Everything is fine besides an USB disk that was connected to the old NAS before.
It appears in the new setup (although not attached) as USBDisk1. It is visible in the Shares overview and also in File Station (but cannot be accessed as the device does not exist).
Unfortunately all buttons are greyed out. How can I remove this device from the NAS? Probably using the shell instead of the web interface?
Thanks in advance!
Remove a "ghost" USB device after migration
- Indyone_de
Re: Remove a "ghost" USB device after migration
Always remember to switch your UI from German to English before posting in an English forum.
What was the migrated unit model? Hope not CAT1 resulting in a legacy volume
- Indyone_de
The old unit was a TS-259 Pro+.
- OneCD
Yep, that's a CAT1 unit.
so best thing to kill the NAS and start from fresh with a full static volume or storage pool
that (hopefully) should also take care of this device
- Indyone_de
Ok, thanks.
