I will try to explain my problem.
Some hours ago I got the message:
[Storage & Snapshots] Set volume "DataVol1" to read-only. Storage pool "1" is full. Ensure the pool has 32.00 GB of free space.
I have a total capacity of 18TB with 9TB free.
The system asked to me to do a filesystem check.
There wasn't any abnormal shutdown and nothing similar.
I tried to make a Filesystem check and I get some messages like:
[Storage & Snapshots] Failed to check file system for volume "DataVol1". Storage pool: 1. Volume could not be unmounted by process "avahi-daemon".
After this I stopped the filesystem check and I rebooted my NAS.
After this I tried to do filesystem check and It never ends correctly, some times I reach 28% others 50% and now finally can't go beyond 1%
I always get the message:
My QNAP model is TS-453B with the firmware 4.5.4.1723 and 4 8TB disk in RAID5.
Any help or idea would be welcome.
I always get a failed to check Filesystem message
Re: I always get a failed to check Filesystem message + unmounted volume
Hi guys,
Here's an upgrade of my problem. Any help would be appreciated.
After the check file system the volume get always unmounted so I couldn't access to my data.
QNAP support managed to mount the volume to let me save all my data, so I did (thank god).
Now all my data is save except an encrypted folder that I wasn't able to unlock with the password, I always get an "Unknown error" (see image).
I'm sure I'm writing the right password and I've also tried from the Shared Folders menu but I didn't see any shared folder (see image).
My admin user was doing strange things and seemed to do not have permissions for anything so I decided to reboot.
After rebooting my admin user was ok but then the problem was that the file system check fails as always an the volume is unmounted again.
QNAP support tried to mount the volume again for me to decrypt the folder an save the data but they couldn't.
Here is what I tried at the moment and some more information commands:
md_checker results:
pvdisplay results:
vgdisplay results:
lvdisplay results:
trying to do an e2fsck after stop the services and also rebooted in maintenance:
With the backup superblock:
Trying to mount the volume:
At this point the volume stays on warning for a few seconds but after remains unmounted again.
Any idea or help will be welcome.
Thanks.
md_checker results:
[~] # md_checker
Welcome to MD superblock checker (v2.0) - have a nice day~
Scanning system...
RAID metadata found!
UUID: fdb1284b:df7ea5c3:4c104f1d:8ac02f22
Level: raid5
Devices: 4
Chunk Size: 64K
md Version: 1.0
Creation Time: May 27 08:36:16 2018
Status: ONLINE (md1) [UUUU]
Enclosure | Port | Block Dev Name | # | Status | Last Update Time | Events | Array State
NAS_HOST 1 /dev/sdc3 0 Active Jul 25 11:01:22 2021 193064 AAAA
NAS_HOST 2 /dev/sdd3 1 Active Jul 25 11:01:22 2021 193064 AAAA
NAS_HOST 4 /dev/sdb3 2 Active Jul 25 11:01:22 2021 193064 AAAA
NAS_HOST 3 /dev/sda3 3 Active Jul 25 11:01:22 2021 193064 AAAA
[~] # pvdisplay
--- Physical volume ---
PV Name /dev/drbd1
VG Name vg1
PV Size 21.80 TiB / not usable 100.00 KiB
Allocatable yes (but full)
PE Size 4.00 MiB
Total PE 5715871
Free PE 0
Allocated PE 5715871
PV UUID FrWs4j-8Pwo-k3jo-Sdyg-uejO-83Gh-22T9g5
[~] # vgdisplay
--- Volume group ---
VG Name vg1
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 5826
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 4
Open LV 1
Max PV 0
Cur PV 1
Act PV 1
VG Size 21.80 TiB
PE Size 4.00 MiB
Total PE 5715871
Alloc PE / Size 5715871 / 21.80 TiB
Free PE / Size 0 / 0
VG UUID zMXX9u-Y0bC-7Eqe-6Qo2-PgIy-hyuX-heu0Hq
[~] # lvdisplay
--- Logical volume ---
LV Name tp1
VG Name vg1
LV UUID kNQhzX-kKQ6-hNoq-UJOJ-a4I2-sPjk-hCIK3S
LV Write Access read/write
LV Creation host, time NAS, 2018-05-27 08:36:19 +0200
LV Pool metadata tp1_tmeta
LV Pool data tp1_tierdata_0
LV Status available
# open 2
LV Size 21.60 TiB
Allocated pool data 100.00%
Allocated pool chunks 45293216
Allocated metadata 2.35%
Current LE 5661652
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 4096
Block device 253:5
LV Path /dev/vg1/lv1
LV Name lv1
VG Name vg1
LV UUID rqAN6g-7d9L-RSuY-YMUv-1Egr-rvCy-9MEFbx
LV Creation host, time NAS, 2018-05-27 08:38:18 +0200
LV Pool name tp1
LV Status available
# open 1
LV Size 18.33 TiB
Mapped size 100.00%
Mapped sectors 39354368000
Current LE 4804000
Segments 1
Allocation inherit
Read ahead sectors 8192
Block device 253:7
LV Path /dev/vg1/lv1312
LV Name lv1312
VG Name vg1
LV UUID PTdmFh-KjcZ-ov24-umCO-fQk8-mlpA-rJpV9J
LV Creation host, time NAS, 2018-05-28 04:00:12 +0200
LV Status available
# open 0
LV Size 2.23 GiB
Current LE 571
Segments 3
Allocation inherit
Block device 253:8
LV Path /dev/vg1/lv544
LV Name lv544
VG Name vg1
LV UUID nbFxOP-I0s0-IZXS-znRz-XwpD-rpfw-iqpAAa
LV Creation host, time NAS, 2018-05-28 04:00:13 +0200
LV Status NOT available
LV Size 144.00 GiB
Current LE 36864
Segments 2
Allocation inherit
[~] # e2fsck -fyv -t -C 0 /dev/mapper/cachedev1
e2fsck 1.43.9 (8-Feb-2018)
DataVol1: recovering journal
Superblock needs_recovery flag is clear, but journal has data.
Run journal anywaye2fsck: Unknown code ____ 251 while recovering journal of DataVol1
e2fsck: unable to set superblock flags on DataVol1
DataVol1: ********** WARNING: Filesystem still has errors **********
[~] # e2fsck -fyv -t -C 0 -b 32768 /dev/mapper/cachedev1
Recovery flag not set in backup superblock, so running journal anyway.
DataVol1: ***** FILE SYSTEM WAS MODIFIED *****
[~] # /etc/init.d/init_lvm.sh
Changing old config name...
Reinitialing...
Detect disk(8, 48)...
dev_count ++ = 0Detect disk(8, 16)...
dev_count ++ = 1Detect disk(253, 0)...
ignore non-root enclosure disk(253, 0).
Detect disk(8, 64)...
ignore non-root enclosure disk(8, 64).
Detect disk(8, 32)...
dev_count ++ = 2Detect disk(8, 0)...
dev_count ++ = 3Detect disk(8, 48)...
/bin/cat: /sys/bus/pci/devices/0000:00:14.0/0000:07:00.0/subsystem_vendor: No such file or directory
sys_startup_p2:got called count = -1
WARNING: duplicate PV FrWs4j8Pwok3joSdyguejO83Gh22T9g5 is being used from both devices /dev/drbd1 and /dev/md1
Found duplicate PV FrWs4j8Pwok3joSdyguejO83Gh22T9g5: using /dev/drbd1 not /dev/md1
Using duplicate PV /dev/drbd1 from subsystem DRBD, ignoring /dev/md1
sh: /sys/block/dm-5/dm/pool/tier/relocation_rate: Permission denied
Done
Thanks.
More info in case it helps:
Dmesg after an e2fsck -fyv -t -C 0 /dev/mapper/cachedev1:
Dmesg after an e2fsck -fyv -t -C 0 -b 32768 /dev/mapper/cachedev1
Dmesg after an /etc/init.d/init_lvm.sh
[87114.626924] buffer_io_error: 301 callbacks suppressed
[87114.632005] Buffer I/O error on dev dm-9, logical block 0, lost async page write
[87114.639406] Buffer I/O error on dev dm-9, logical block 1, lost async page write
[87114.646814] Buffer I/O error on dev dm-9, logical block 3, lost async page write
[87114.654228] Buffer I/O error on dev dm-9, logical block 4, lost async page write
[87114.661641] Buffer I/O error on dev dm-9, logical block 5, lost async page write
[87114.669060] Buffer I/O error on dev dm-9, logical block 6, lost async page write
[87114.676472] Buffer I/O error on dev dm-9, logical block 7, lost async page write
[87114.683965] Buffer I/O error on dev dm-9, logical block 8, lost async page write
[87114.691421] Buffer I/O error on dev dm-9, logical block 9, lost async page write
[87114.698827] Buffer I/O error on dev dm-9, logical block 10, lost async page write
[87124.839414] buffer_io_error: 4137 callbacks suppressed
[87124.839417] Buffer I/O error on dev dm-9, logical block 605585408, lost async page write
[87501.695416] Buffer I/O error on dev dm-9, logical block 1, lost async page write
[87501.702837] Buffer I/O error on dev dm-9, logical block 2, lost async page write
[87501.710241] Buffer I/O error on dev dm-9, logical block 3, lost async page write
[87501.717658] Buffer I/O error on dev dm-9, logical block 4, lost async page write
[87501.725078] Buffer I/O error on dev dm-9, logical block 5, lost async page write
[87501.732539] Buffer I/O error on dev dm-9, logical block 6, lost async page write
[87501.739998] Buffer I/O error on dev dm-9, logical block 7, lost async page write
[87501.747450] Buffer I/O error on dev dm-9, logical block 8, lost async page write
[87501.754877] Buffer I/O error on dev dm-9, logical block 9, lost async page write
[87501.762330] Buffer I/O error on dev dm-9, logical block 10, lost async page write
[87653.512056] buffer_io_error: 7971 callbacks suppressed
[87653.512059] Buffer I/O error on dev dm-9, logical block 0, lost async page write
[87653.524648] Buffer I/O error on dev dm-9, logical block 1, lost async page write
[87653.532057] Buffer I/O error on dev dm-9, logical block 3, lost async page write
[87653.539468] Buffer I/O error on dev dm-9, logical block 4, lost async page write
[87653.546891] Buffer I/O error on dev dm-9, logical block 5, lost async page write
[87653.554302] Buffer I/O error on dev dm-9, logical block 6, lost async page write
[87653.561738] Buffer I/O error on dev dm-9, logical block 7, lost async page write
[87653.569154] Buffer I/O error on dev dm-9, logical block 8, lost async page write
[87653.576591] Buffer I/O error on dev dm-9, logical block 9, lost async page write
[87653.584021] Buffer I/O error on dev dm-9, logical block 10, lost async page write
[87653.654125] JBD2: recovery failed
[87653.657464] EXT4-fs (dm-9): error loading journal
[87654.716559] EXT4-fs (dm-9): INFO: recovery required on readonly filesystem
[87654.723463] EXT4-fs (dm-9): write access will be enabled during recovery
[87654.784342] JBD2: recovery failed
[87654.787725] EXT4-fs (dm-9): error loading journal
[87655.616659] EXT4-fs (dm-9): can't mount with data=, fs mounted w/o journal
[87658.627889] device-mapper: tier: set allocation tier failed
