Stopping and Starting Specific Services on boot
daNutz
Getting the hang of things
Post by daNutz »
I use Container Station and one of the containers is pihole, the requirement i have is;
  1. to stop DNSMASQ starting on boot (stops pihole starting, both use port 53)
  2. to execute my docker compose script after container station has started
How to i achieve this? im familiar with using CLI and WinSCP
thanks for all the help.
TS-1079Pro - 30TB - RAID 6 - FW: 4.3.6.2232 - MultiMedia
TS-453 Pro - 12TB - RAID 5 - OS: Ubuntu Server 22.04.2 / Docker
SelfHosted
NAS Migration Compatibility
daNutz
Re: Stopping and Starting Specific Services on boot
Post by daNutz »
Ok, currently trying to use OneCD's RunLast with a script that has the following code:
#!/bin/sh
docker-compose up -d
killall -9 dnsmasq
docker-compose up -d pihole
Unfortunately RunLast seems to be running before container stations is started, even though ive also installed his SortMyQPKG's that has the following order;
(01) (A) HideThatBanner
(02) (A) Entware
(03) (A) netmgr
(04) (A) container-station
(05) (A) HybridBackup
(06) (Φ) NotificationCenter
(07) (Φ) QuLog
(08) (Φ) ResourceMonitor
(09) (Φ) Qboost
(10) (Φ) SSDLaboratory
(11) (Φ) helpdesk
(12) (Φ) QsyncServer
(13) (Φ) CloudLink
(14) (Φ) LicenseCenter
(15) (Φ) QcloudSSLCertificate
(16) (Φ) sherpa
(17) (Φ) duf
(18) (Φ) ClamAV
(19) (Ω) MalwareRemover
(20) (Ω) RunLast
(21) (Ω) SortMyQPKGs
SelfHosted
OneCD
Post by OneCD »
daNutz wrote: Sun Jul 25, 2021 7:34 pm Unfortunately RunLast seems to be running before container stations is started, even though ive also installed his SortMyQPKG's that has the following order;
I don't have access to Container Station so I'm unable to test how and when it starts.
Maybe it takes a while to start and doesn't wait for all containers to be up-and-running before releasing control back to QTS to continue processing QPKGs?
You'll need to do some testing and find a workaround. ;)
daNutz
Post by daNutz »
OneCD wrote: Mon Jul 26, 2021 2:53 pm
Hi, I did do some checks and noticed that RunLast was executing before container station, even though in the QPKG order it is set to be near the end (as per above). not sure how i can diagnose why its being started sooner than it should?
SelfHosted
OneCD
Post by OneCD »
daNutz wrote: Mon Jul 26, 2021 7:16 pm Hi, I did do some checks and noticed that RunLast was executing before container station, even though in the QPKG order it is set to be near the end (as per above). not sure how i can diagnose why its being started sooner than it should?
Hard-to-say. You may need to hack the QPKG service-script files and insert your own tracking logger (example: something that appends the current NAS uptime to a text file would do) to work out when Container Station initially starts, then as it's loading its containers, then again when it exits, and compare this against the start times for RunLast. It's a pain, but it should help you discover when it starts compared to your other QPKGs. :D
The "theory" RunLast (and SortMyQPKGs) work-on is that QPKGs are started in the order they appear in [/etc/config/qpkg.conf] but I found at-least one exception to that some time back (read the OP here for more info).
daNutz
Post by daNutz »
OneCD wrote: Tue Jul 27, 2021 7:11 am
Unforutenty im not that intelligent, i tried it on my second nas and had the same issue :(
This is what the log says, which is why im assuming container station hasn't started;
RunLast (20210328)
[Sun Jul 25 12:07:53 BST 2021] begin "start" scripts ...
[Sun Jul 25 12:07:53 BST 2021] -> execute: "'/share/CACHEDEV1_DATA/.qpkg/RunLast/scripts/DockerCompose.sh'" ...
[Sun Jul 25 12:07:53 BST 2021] => exitcode: (127)
[Sun Jul 25 12:07:53 BST 2021] => stdout: ""
[Sun Jul 25 12:07:53 BST 2021] => stderr: "/share/CACHEDEV1_DATA/.qpkg/RunLast/scripts/DockerCompose.sh: line 1: docker-compose: command not found"
[Sun Jul 25 12:07:53 BST 2021] end "start" scripts
SelfHosted
daNutz
Post by daNutz »
ok since upgrading to 20210809, im no longer seeing errors in the log, but its also doesn't look to be executing my script :(
RunLast (20210809)
[Sun Aug  8 20:07:31 BST 2021] begin "start" scripts ...
[Sun Aug  8 20:07:31 BST 2021] end "start" scripts
SelfHosted
OneCD
Post by OneCD »
Is your script still there?
You might also need to do this too: viewtopic.php?p=796372#p796372 except with the 'docker-compose' command.
daNutz
Post by daNutz »
OneCD wrote: Mon Aug 09, 2021 3:38 am Is your script still there?
You're a superstar, thank you!, its now all working :)
SelfHosted
OneCD
Post by OneCD »
Good work! :D
