Volumes vanished!
iglazer
Volumes vanished!
Post by iglazer »
I can back from a few days away to find a message in my QNAP that there were no volumes or storage pools! I am hoping people have some pointers. The following are a few things I tried based on other posts. Appreciate any and all help!
qcli_storage -d
[~] # qcli_storage -d
Enclosure  Port  Sys_Name          Type      Size      Alias             Signature   Partitions  Model
NAS_HOST   1     /dev/sdc          SSD:data  232.89 GB M.2 SSD 1         QNAP FLEX   5           WDC WDS250G2B0B-00YS70
NAS_HOST   2     /dev/sdd          SSD:data  232.89 GB M.2 SSD 2         QNAP FLEX   5           WDC WDS250G2B0B
NAS_HOST   3     /dev/sdf          SSD:data  931.51 GB SSD 1             QNAP FLEX   5           Crucial CT1000MX500SSD1
NAS_HOST   4     /dev/sde          SSD:data  931.51 GB SSD 2             QNAP FLEX   5           Crucial CT1000MX500SSD1
NAS_HOST   5     /dev/sdh          HDD:data  3.64 TB   Disk 1            QNAP FLEX   5           HGST HUS726040ALE610
NAS_HOST   6     /dev/sdg          HDD:data  3.64 TB   Disk 2            QNAP FLEX   5           HGST HUS726040ALE610
NAS_HOST   7     /dev/sdb          HDD:data  3.64 TB   Disk 3            QNAP FLEX   5           Seagate ST4000VN000-1H4168
NAS_HOST   8     /dev/sda          HDD:data  3.64 TB   Disk 4            QNAP FLEX   5           Seagate ST4000VN000-1H4168
df -h
[~] # df -h
Filesystem                Size      Used Available Use% Mounted on
none                    400.0M    280.0M    120.0M  70% /
devtmpfs                  7.8G      8.0K      7.8G   0% /dev
tmpfs                    64.0M    412.0K     63.6M   1% /tmp
tmpfs                     7.8G    136.0K      7.8G   0% /dev/shm
tmpfs                    16.0M     92.0K     15.9M   1% /share
/dev/sdi5                 7.7M     53.0K      7.3M   1% /mnt/boot_config
tmpfs                    16.0M         0     16.0M   0% /mnt/snapshot/export
/dev/md9                499.5M    150.7M    348.8M  30% /mnt/HDA_ROOT
cgroup_root               7.8G         0      7.8G   0% /sys/fs/cgroup
/dev/md13               417.0M    386.8M     30.2M  93% /mnt/ext
/dev/ram2               433.9M      2.3M    431.6M   1% /mnt/update
tmpfs                    64.0M      3.2M     60.8M   5% /samba
tmpfs                    48.0M    100.0K     47.9M   0% /samba/.samba/lock/msg.lock
tmpfs                    16.0M         0     16.0M   0% /mnt/ext/opt/samba/private/msg.sock
cat /proc/mdstat
md4 : active raid1 sdc3[0] sdd3[1]
      234243584 blocks super 1.0 [2/2] [UU]
md3 : active raid1 sde3[0]
      870126592 blocks super 1.0 [1/1] [U]
md2 : active raid1 sdf3[0]
md1 : active raid6 sdh3[0] sda3[3] sdb3[2] sdg3[1]
      7794126848 blocks super 1.0 level 6, 512k chunk, algorithm 2 [4/4] [UUUU]
      bitmap: 0/30 pages [0KB], 65536KB chunk
md322 : active raid1 sda5[3](S) sdb5[2](S) sdg5[1] sdh5[0]
      7235136 blocks super 1.0 [2/2] [UU]
      bitmap: 0/1 pages [0KB], 65536KB chunk
md256 : active raid1 sda2[3](S) sdb2[2](S) sdg2[1] sdh2[0]
      530112 blocks super 1.0 [2/2] [UU]
md321 : active raid1 sdd5[2] sdc5[0]
      8283712 blocks super 1.0 [2/2] [UU]
md13 : active raid1 sdf4[0] sde4[36] sdd4[35] sda4[34] sdb4[33] sdc4[32] sdg4[2] sdh4[1]
      458880 blocks super 1.0 [32/8] [UUUUUUUU________________________]
      bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sdf1[0] sde1[36] sdd1[35] sda1[34] sdb1[33] sdc1[32] sdg1[2] sdh1[1]
      530048 blocks super 1.0 [32/8] [UUUUUUUU________________________]
unused devices: <none>
