Im a novice to this type of stuff, so please be patient with me.
Im trying to create a new volume on my NAS TS-453BT3. Im doing this to create a volume to store surveliance videos.
When I try to create a the volume I get message Pool free space is not enough. Im not sure why?
Im uploaded a couple images that might help.
Error creating a volume
Re: Error creating a volume
- Easy as a breeze
Your first (system) volume is taking the whole pool space. You can either do one of two things:
1. Shrink your existing thick volume and use the free pool space to create your second volume.
2. Just create a second share on your existing volume.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
Thank you. I will give that a go.
