Hello everyone.
I'm having an issue with one of my HD
It's a WD RED WD30EFRX which was installed a few months ago, which should be working perfectly fine.
I got an I/O error in the disk health, so the data volume is degraded. I'm quite sure the HD isn't a problem, as I moved it to my desktop, where it didn't detect any problem and it runs fine.
I've been a full scan and format on the desktop PC.
I tried doing a bad block scan and try to delete the I/O error history, but now the NAS detects bad blocks, when no bad blocks were found while scanning on the desktop PC, and SMART information doesn't show any error.
Is there any way to reset/ clear the Disk Access History I/O??
I attach screenshots of the errors I'm facing.
Thanks for any suggestion
Clearing "Disk Access History I/O" error ?? - how is it done?
QNAP TS-251 8GB RAM
2X 3TB WD RED WD30EFRX set as RAID 1
FW: QTS 4.5.1.1495
FW: QTS 4.5.1.1495
Re: Clearing "Disk Access History I/O" error ?? - how is it done?
clear the disk with dispart (clean) and try again
it could also be a busted port on your nas
Thank for the reply.
The port is fine as I tried replacing bays, and the port is fine now with another disk. I'm having the same error on the disk with the I/O problem also on the second bay.
do you mean using diskpart while connected to my desktop PC? What is the specific command I should use? is it like this one?
https://www.seagate.com/em/en/support/k ... -005929en/
Thank you
QNAP TS-251 8GB RAM
FW: QTS 4.5.1.1495
FW: QTS 4.5.1.1495
Yes, see my other post viewtopic.php?f=25&t=162576&p=799667#p799667.
In short, the information is stored in
/mnt/HDA_ROOT/.conf
Cameo,
Great info, I am not finding /mnt/HDA_ROOT/.conf in my NAS files (TS-451D2). Any ideas?
it's hidden .. try to open/edit it anyways
e.g.
Do that as admin user and you should see content
e.g.
vi /mnt/HDA_ROOT/.conf
execute this command in SSH:
sed -i '/pd_err_wwn_/d' /mnt/HDA_ROOT/.conf
if the error persists, repeat the command, do the bad block scan and choose to clear the previous io error.
