QFinder shows ver 1.0208.0101 when discs are connected & web refuses to connect... more crazy issues
Model TS-453a
So much happened to get me here, It started with the NAS throwing the volume into a read-only state because 2 of the 4 HDDs had errors. I was hoping to scan the HDDs for bad blocks enough to get it up into a bit of a "limp mode" until new drives arrive, but somehow I have my NAS in the following state:
The admin password has been reset (I did not do that myself)
• If I boot up with no HDDs inserted, I can connect to the web interface. It shows the latest firmware (4.xxx from July 27th or thereabouts.) and, naturally, looks like it's a fresh new NAS and wants me to set it up.
• If I boot with the HDDs inserted, it shows a version of 1.0208.0101 in QFinder. I can SSH in, but the web interface refuses the connection.
I'm just baffled. halp!
Re: QFinder shows ver 1.0208.0101 when discs are connected & web refuses to connect... more crazy issues
It should not have been exposed to the WAN, save for specific ports to some services, no. ¯\_(ツ)_/¯
- OneCD
Then that's a "yes".
Which services?
Plex was allowed in. VPN, as well.
Actually, here's a list TCP/UDP: 2234,2300-2400,6073,6667,28800-29100,47624,50000-50100
that is alot of ports for just plex and vpn
also were they forwarded or redirected?
if ony of these ports redirected to 8080..then you are exposed
All are tagged as forwards
FYI the HD status lights on my NAS are as follows:
1: green
2: off
3: red
4: red
1: green
2: off
3: red
4: red
well anyways...try malware remover and/or open a ticket with qnap support so they can investigate
Are you aware of a way to run the malware remover who I only have SSH access? Thanks
For what it's worth, when I run a I can see that MalwareRemover is running.
cat /etc/config/qpkg.conf | grep \]
check your cron to see what script is invoked when MR starts
also check cron and autostart.sh for malware (most of the time cryptic entries)
- OneCD
It also sounds like you may be running with UPnP enabled on the router. Please disable this service in the router and remove all ports forwarded to the NAS. Then reboot your router to ensure they’re closed.
