Unable to create shared folders ...
uakm2201
Post by uakm2201 »
Hello all
Im' on QTS Hero latest version.
I try to create a shared folders on my second Volume on this errors appears.
Erreur 2021-08-03 16:35:48 --- 127.0.0.1 --- --- [Share Folders] Create snapshot shared folder [TimeBackup] failed. Create volume failed.
After that, all shared forlders dissapears from the interface ...
Any ideas ?
PS : I've create manually some folders to restore some backups without using interface
On the command line, everything is present ...
NAME USED AVAIL REFER MOUNTPOINT
zpool1 4.86T 2.89T 224K /zpool1
zpool1/zfs1 1.00G 1000M 23.8M /share/ZFS1_DATA
zpool1/zfs1@:init: 140K - 172K -
zpool1/zfs1107 79.4G 79.4G 172K /zpool1/zfs1107
zpool1/zfs18 659K 2.89T 336K /share/ZFS18_DATA
zpool1/zfs18@:init: 140K - 172K -
zpool1/zfs18/RecentlySnapshot 184K 2.89T 184K /share/ZFS18_DATA/homes/@Recently-Snapshot
zpool1/zfs2 3.08T 2.89T 3.08T /share/ZFS2_DATA
zpool1/zfs2@:init: 140K - 172K -
zpool1/zfs2/RecentlySnapshot 184K 2.89T 184K /share/ZFS2_DATA/Public/@Recently-Snapshot
zpool1/zfs3 144G 2.89T 144G /share/ZFS3_DATA
zpool1/zfs3@:init: 140K - 172K -
zpool1/zfs3/RecentlySnapshot 184K 2.89T 184K /share/ZFS3_DATA/Multimedia/@Recently-Snapshot
zpool1/zfs4 311K 2.89T 204K /share/ZFS4_DATA
zpool1/zfs4@:init: 108K - 172K -
zpool1/zfs5 1.26M 2.89T 980K /share/ZFS5_DATA
zpool1/zfs5@:init: 132K - 172K -
zpool1/zfs5/RecentlySnapshot 184K 2.89T 184K /share/ZFS5_DATA/Recordings/@Recently-Snapshot
zpool1/zfs530 11.0G 2.89T 1.87G /share/ZFS530_DATA
zpool1/zfs530@:init: 140K - 172K -
zpool1/zfs530/zfs5300001 9.16G 2.89T 45.0M /share/ZFS530_DATA/.qpkg/container-station/docker
zpool2 8.85T 22.5T 204K /zpool2
zpool2/zfs1108 144G 144G 172K /zpool2/zfs1108
zpool2/zfs19 26.8M 2.00T 26.5M /share/ZFS19_DATA
zpool2/zfs19@:init: 140K - 172K -
zpool2/zfs19/RecentlySnapshot 184K 22.5T 184K /share/ZFS19_DATA/Container/@Recently-Snapshot
zpool2/zfs20 179G 333G 179G /share/ZFS20_DATA
zpool2/zfs20@:init: 140K - 172K -
zpool2/zfs20/RecentlySnapshot 192K 22.5T 192K /share/ZFS20_DATA/ITunesMac/@Recently-Snapshot
zpool2/zfs21 181G 22.5T 181G /zpool2/zfs21
zpool2/zfs21@backup 25.2M - 181G -
zpool2/zfs532 2.08T 22.5T 2.08T none
zpool2/zfs532@backup 4.73M - 2.08T -
zpool2/zfs800 196K 10.0T 196K /share/ZFS800_DATA
zpool2/zfs900 343K 22.5T 204K /share/ZFS531_DATA
zpool2/zfs900@:init: 140K - 172K -
zpool256 1.00M 383M 144K /zpool256
dolbyman
Re: Unable to create shared folders ...
Post by dolbyman »
sounds like you should open a ticket with qnap
