We use a QNAP TS-231P unit and we just bought a QNAP TS-231K
Both units use dual 4TB Hds in mirroring mode
We would like to:
- clone TS-231P over Ts-231K (all settings)
- synchronize changes daily
Is this feasible?
Cloning two NAS?
Re: Cloning two NAS?
38 views and no reply mean this cannot be done automatically!
- Easy as a breeze
cloning data automatically on an ongoing basis should be easy via Hybrid Backup Station (someone else can explain the details, I don't use it). You could do a backup of settings (manually from the WebUI) and restore them to the other system (manually) assuming they are both on the same firmware version. That would be a one time thing that you do manually but do you really need the configuration of the two devices synced automatically every day? Generally you configure the settings once and then don't touch them for quite some time. If you ever do make adjustments you'd make that same adjustment to both systems.
Exactly, I would clone once, then synchronise manually using Fastcopy
settings cannot be cloned..even the manual settings backup cannot be used spanning device models
Is there a way to one-click backup the whole NAS to the secondary one, eventually using an app on the NAS?
That would be a NAS to NAS operation...
no such function..no
Closest idea to achieve so?
just backup the data over regularly with hbs 3
HBS 3 is the perfect tool!
