NAS: TVS-882BR
FW: 4.5.2.1566
NAS: TVS-663
FW: 4.5.4.1741
The NAS devices are unable to send messages from Notification Center(NC). I have had this problem for long time now and with prior versions of the FW. I opened a ticked many, many moths ago with support and they said that the issue is because I run dnsmasq on the NAS (both run it). The strange thing is that I can send a test email from the NC and if I click resend on a message in the NC it gets sent with no issues. Anyone have any idea why NC cannot send the message the first time? Everything else on the NAS runs fine and has no problem accessing the LAN/WAN. All devices on the network are able to use dnsmasq with no issues.
Notification Center - Unable to Send
- Don
- Don
Re: Notification Center - Unable to Send
No one?
Nope..sorry..I dont use email notifications
- Easy as a breeze
Seeing this the first time for my TS-873U-RP with QTS 4.5.4.1787 build 20210910. The TS-1635AX is doing fine on this version.
Will test the next Firmware in a couple of weeks, ticket is created, but no response yet.
NAS (production): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
NAS (backup): TS-1635AX FW: QTS 5.1.4.2596 build 20231128
Data (QTier): [RAID-6] 4 x 4TB Samsung 870 QVO Sata
Data (HDD): [RAID-6] 7 x 18TB Exos
RAM: 8 GB (QNAP shipped)
UPS: CyberPower CP900EPFCLCD
Usage: SMB with rclone (encrypted)
NAS: TS-873U-RP FW: QTS 5.1.4.2596 build 20231128
BACKUP: 4TB Synology DS214 FW: DSM 7.0.41890
Usage: SMB, Backup Domain Controller
- Don
Are you running dnsmasq?
- Easy as a breeze
No, OPNsense with Unbound DNS.
It worked just fine, until I updated to 1787.
- Easy as a breeze
Got to do some tests, as noted somewhere else here on the forum a reboot of the NAS and router solved the connectivity issue and the notification center was able to send again.
