Replace Disks After MB Failure
The motherboard in my TVS-672XT failed and I had to send the unit it to have the motherboard replaced. I had to pull all the drives (2 M.2 and 6 HDD) I labeled them for their location in the unit as I removed them. I now have the unit back. What is the best way to replace them and restore the unit to the previous Raid Set up?
Re: Replace Disks After MB Failure
make sure the new device is on the latest firmware (disk-less via qfinder) then just stick all disks in the same way you removed them and it should come up the same way as before.
There is a whole thread about the failing x72XT units and how people got their warranty extended, hope you didn't pay for yours
viewtopic.php?f=50&t=153097
Thank You! Thank You! dolbyman. Everything went flawlessly.....Yes, fortunately it was covered under warranty.
