Performed a "reset settings" on my
TS-251+ QTS version 4.5.4.1787.
After rebooting, I setup the 500gb ssd as a new volume.
I attempted to "attach and recover" the volume on the 6TB drive through QTS which
produced an error: "no storage pools or volumes detected.
Screenshot included below.
screenshot of command attached below:
cat /proc/mdstat
screenshot of command attatched below:
/etc/init.d/init_lvm.sh
Any suggestions are appreciated.
Data isn't mission critical but would be nice to know how to recover from problem
TIA
Reset settings drive volume problem
Re: Reset settings drive volume problem
The old drive was probably the system drive .. now you have two system drives
Remove the SSD and start with only the 6TB drive to confirm.
Ok,
- Removed ssd and booted with just the hdd
- cat /proc/mdstat
Tried recover -> attach and recover in QTS
thank you for your assistance
- cat /proc/mdstat
[~] # cat /proc/mdstat
md322 : active raid1 sda5[0]
7235136 blocks super 1.0 [2/1] [U_]
bitmap: 1/1 pages [4KB], 65536KB chunk
md256 : active raid1 sda2[0]
530112 blocks super 1.0 [2/1] [U_]
md13 : active raid1 sda4[1]
458880 blocks super 1.0 [64/1] [_U______________________________________________________________]
md9 : active raid1 sda1[1]
530048 blocks super 1.0 [64/1] [_U______________________________________________________________]
unused devices: <none>
[~] # /etc/init.d/init_lvm.sh
Changing old config name...
Reinitialing...
Detect disk(8, 16)...
ignore non-root enclosure disk(8, 16).
Detect disk(8, 32)...
ignore non-root enclosure disk(8, 32).
Detect disk(8, 0)...
dev_count ++ = 0Detect disk(8, 16)...
sys_startup_p2:got called count = -1
Done
then a ticket with qnap could be a good next step
