I received this error "RAID Group recovery failed"
in ssh i do:
[~] # cat /proc/mdstat
md322 : active raid1 sdf5[7](S) sda5[0] sdh5[6](S) sdg5[5](S) sde5[4](S) sdd5[3](S) sdc5[2](S) sdb5[1]
7235136 blocks super 1.0 [2/2] [UU]
bitmap: 0/1 pages [0KB], 65536KB chunk
md13 : active raid1 sdf4[6] sda4[0] sdg4[7] sdh4[5] sde4[4] sdd4[3] sdc4[2] sdb4[1]
458880 blocks [12/8] [UUUUUUUU____]
bitmap: 1/1 pages [4KB], 65536KB chunk
md9 : active raid1 sdf1[6] sda1[0] sdg1[7] sdh1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1]
530048 blocks [12/8] [UUUUUUUU____]
unused devices: <none>
[~] # df -h
Filesystem Size Used Available Use% Mounted on
none 200.0M 183.3M 16.7M 92% /
devtmpfs 1.5G 8.0K 1.5G 0% /dev
tmpfs 64.0M 636.0K 63.4M 1% /tmp
tmpfs 1.5G 0 1.5G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/md9 509.5M 166.6M 342.8M 33% /mnt/HDA_ROOT
cgroup_root 1.5G 0 1.5G 0% /sys/fs/cgroup
/dev/md13 371.0M 336.5M 34.5M 91% /mnt/ext
/dev/ram2 433.9M 2.3M 431.6M 1% /mnt/update
tmpfs 64.0M 2.4M 61.6M 4% /samba
tmpfs 16.0M 28.0K 16.0M 0% /samba/.samba/lock/msg.lock
tmpfs 16.0M 0 16.0M 0% /mnt/ext/opt/samba/private/msg.sock
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
[~] # md_checker
Welcome to MD superblock checker (v1.4) - have a nice day~
Scanning system...
HAL firmware detected!
Scanning Enclosure 0...
RAID metadata found!
UUID: d2415754:719330c6:e32781cd:40701f19
Level: raid5
Devices: 7
Chunk Size: 64K
md Version: 1.0
Creation Time: Jul 21 12:18:00 2014
Status: OFFLINE
Disk | Device | # | Status | Last Update Time | Events | Array State
1 /dev/sda3 0 Rebuild Sep 15 10:05:29 2021 38563934 AAAAARA
2 /dev/sdb3 1 Active Sep 15 10:05:29 2021 38563934 AAAAARA
3 /dev/sdc3 2 Active Sep 15 10:05:29 2021 38563934 AAAAARA
4 /dev/sdd3 3 Active Sep 15 10:05:29 2021 38563934 AAAAARA
5 /dev/sde3 4 Active Sep 15 10:05:29 2021 38563934 AAAAARA
6 /dev/sdf3 5 Active Sep 15 09:56:09 2021 38556715 AAAAAAA
8 /dev/sdh3 5 Rebuild Sep 15 10:05:29 2021 38563934 AAAAARA
7 /dev/sdg3 6 Active Sep 15 10:05:29 2021 38563934 AAAAARA
WARNING: Duplicate device detected for #(5)!
