Hi
I have an ts 251b, and its been working flawle... almost flawless during these years. But now i get the message "A system failure occurred. The device has insufficient system storage, check system disc partition". I understand that I'm not the first one to have this issue, but i honestly dont understand the other threads good enough for it to help me.
I have 8gb ram, 2 discs with 8 tb on each runinng in a RAID 1 config.
I have been able to check the storage, and my folders take up about 2.5 tb, but under storage and snapshots it shows that the disc is full.
What taking up all this space? How do I find it? I would be most grateful for any help..
Also sorry that the attached pictures are in swedish..
Insufficient storage, but where to find what takes up the space?
Re: Insufficient storage, but where to find what takes up the space?
Thank you. Hadn't seen it.
So the solution is probably patience..
No, referring to the link disable the SSD profiling app and message should disappear.
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
No it doesn't. It shows that your storage pool (Lagringspool) is full because you created a maximum size thick volume (Tjock volym) in it using up all of the pool storage. It look like the thick volume is only filled to around 40% with data so you still have plenty of space left in the virtual "disc" that is your volume.
