G'day all,
I hope Im asking in the right forum if not happy to have my question moved to the appropriate location.
Qnap 212 first time owner of a qnap product - new user to the product but not new to crashing and burning systems .
I've done a search of the forum and not having much luck..
Simple question is there a switch to enable "root access" to the qnap os or an app by which to access it the web file management system seems not to be able to do this ? ..
Reason I want this is simply to be able to find what I've installed on the system ie python (where does it live) - sabnzbd I would simply like to update it - I know how just want to know where to access the files.
If someone could be so kind as to post a link where I can read on how to enable root access it would be much appreciated.
Regards and thanks in advance
root access
- schumaku
Re: root access
Use ssh to login as admin ... in fact the root account is named admin on the QNAP NAS.
Do _not_ try to establish a share pointing to the NAS system and U**x root - by far to much risks, to many side effects, ...
For sabnzbd - please stick to the related forum ... http://forum.qnap.com/viewforum.php?f=133 The package maintainer is very active in keepin'it up-to-date, as of writing SABnzbd+ 0.6.15 (15-02-2012) -> http://forum.qnap.com/viewtopic.php?f=1 ... 63#p160566
Re: root access
oh hey well that took all of 5 minutes for a reply - very gratefull for that. I hear the warning bells but am able to handle most extreme issues - I just like to have full access and see where what is.. like most it/t users if I cant control it I dont want it ..
Thank you for the links to sabnzb much appreciated - I need to install the other packages as well sickbeard and the like one of the reasons why I was asking for root access I cant seem to find a package for sickbeard so was thinking of doing it manually.
edit that when one opens ones eyes its suprising what you can find - found everything I needed on QPKG beta section of the forum.
all I need is that root access to see where it all goes - I can't help myself - I just need a GUI and I'm racing.
As a by the by havent had an issue installing or running anything on the qnap so far, touch wood - I just need to learn how its directory structure runs for telling other apps where to look for and find things.
Regards and thank you again
Re: root access
Hey gday again im sure some one out there would like to share how to enable root access
Re: root access
For root access:
$ ssh admin@qnap-ip
If you need a GUI, you can install midnight commander (command "mc"). That'll give you a console-based (G)UI.
If you need something still more graphical, you can use any graphical SFTP client.
Are you using Linux?
$ ssh admin@qnap-ip
Re: root access
Hey thank you for the reply,
I'm using win7 x64 - and have Winscp so easy enough to see whats where - thank you for the ssh tip, its much appreciated.
Its the first time I've really played with linux - I used unix 20 + + + years ago my memory isnt what it used to be - I blame old age for that..
I'm just trying to create a familiar working environment for me to use.. when logged into the qnap without having to rely on windows..
I'll give midnight commander a go - I had a look at Krusader but its a little beyond my current skill set to install it.
Thank you again for the reply and tip.
Regards
Regards
Re: root access
Sorry to resurrect a really old thread, but I am trying to get FTP root access to my QNAP NAS, and using SSH (in CoreFTP) gives me an error when logging on
Is there something else I need to do to get ftp access as root? I need to view/copy some files from /etc/ to troubleshoot an NFS sharing problem
SFTP connection error - SFTP subsystem on server unavailable
- Don
Re: root access
Don’t post to nine year old topics. Please start a new topic and include all pertinent information.
