I have an TS-869L (Firmware Version 4.0.2).
I have just played with the encryption option of one disk.
On the web interface I have created an encrypted disk on the whole disk.
After that I have unplugged the disk and plugged it into an debian 7 system.
The disk in my system is shown as "sdc" and sdc3 is the encrypted partition.
So I tried the following:
cryptsetup luksOpen /dev/sdc3 encdisk
Enter Password:
... failed
But does not work.
After that I see the option for downloading an keyfile on the web interface.
I downloaded it (took ages for for 256k -.-) and tried it out
cryptsetup luksOpen /dev/sdc3 encdisk --key-file=/tmp/mykey.key
... failed
Looks like qnap does some obfuscating with the password and the keyfiles.
I need to know what I have to do that I can mount the encrypted volume on other systems.
I think a snipped of the obfuscating code would be enough.
keros
