My QNAP is TS-219P+. I bought a new hard disk, and put it into the disk slot 1. After I have set all the file sharing folders, I put into the old Disk into Slot 2 and want to transfer the files into the new hard disk. But I found all the default file sharing folders are automatically switched to the old disk(disk 2).
Question: How can I move the default sharing from old disk(slot2) to the new disk(slot1)? e.g. Multimedia, Public, Download, Recordings
how to move default file sharing to another disk
- pwilson
Re: how to move default file sharing to another disk
The official answer is already in the fine manual.fourooms wrote:My QNAP is TS-219P+. I bought a new hard disk, and put it into the disk slot 1. After I have set all the file sharing folders, I put into the old Disk into Slot 2 and want to transfer the files into the new hard disk. But I found all the default file sharing folders are automatically switched to the old disk(disk 2).
That being said, it is possible to change these, but doing so requires a thorough understanding of Linux, and the ability to manually edit configuration files, and the ability to manipulate directories, and ACLs (Access Control Lists).
Sorry for the vagueness of this response, but in the absence of any of the information requested in article: When you're asking a question, please include the following, (except your NAS model), nor an understanding of your Linux and "vi" skills, I believe your best bet would be to contact QNAP Customer Service, and ask them to do it for you. (They might decline, referring you to the above quoted text from the fine manual).
Patrick M. Wilson
Victoria, BC Canada
Weird. Wonder why the manual is wrong again, and it changed from the first disk volume inserted away to the second one.
It is possible to move the shares, I did it by changing the paths in the smb config file, but I wouldn't do that without backups if I was you
Hmm then why does dropbox tell me to move the 'home' share to another volume less than 16tb ? and a tech support reply tell me to do this?pwilson wrote:The official answer is already in the fine manual.fourooms wrote:My QNAP is TS-219P+. I bought a new hard disk, and put it into the disk slot 1. After I have set all the file sharing folders, I put into the old Disk into Slot 2 and want to transfer the files into the new hard disk. But I found all the default file sharing folders are automatically switched to the old disk(disk 2).
Obvioulsy for me would be easier to tell dropbox where to locate it's files. i.e. I create a small volume for dropbox and have dropbox use that.
- pwilson
Please provide the output of:szhjcn wrote:Hmm then why does dropbox tell me to move the 'home' share to another volume less than 16tb ? and a tech support reply tell me to do this?pwilson wrote:The official answer is already in the fine manual.fourooms wrote:My QNAP is TS-219P+. I bought a new hard disk, and put it into the disk slot 1. After I have set all the file sharing folders, I put into the old Disk into Slot 2 and want to transfer the files into the new hard disk. But I found all the default file sharing folders are automatically switched to the old disk(disk 2).
echo "Dropbox is installed in: \"$(getcfg -f /etc/config/qpkg.conf dropbox install_path)\""
echo "\"Homes\" directory is stored at \"$(getcfg -f /etc/config/smb.conf homes path)\""
#done
Patrick M. Wilson
Victoria, BC Canada
Found out from a tech reply (thanks QNAP) that you can just:
Goto: Control Panel --> Users --> Home (Button) and move the Home to a different volume.
Obviously you need to setup a new volume first.
I unistalled dropbox, then I rebooted after moving the Home Dir then re-installed Dropbox. Syncing now.
- DanTheMan
With QTS 4.3.3 the button is called "Home Folder" and it just defines on which drive the home folders are to be found. If they don't exist on the specified drive, they will be created.szhjcn wrote:Found out from a tech reply (thanks QNAP) that you can just:
However, data is not moved. If you choose a different drive from the current one, the old home folders are simple deleted - without any hints or warnings.
Whoa, glad I had made a backup.
why reply to a 2014 thread ?
- DanTheMan
Thread was quite at the top of a Google search result so I thought that I might as well add my 5 cents to it.
