Delete .symform folders.
newowner
First post
Post by newowner »
I have got a QNAP 469Pro with the latest firmware 3.8.1.
I have created a symform folder, sync'd the folder and have decided to re-organise the folder structure. I have decided to delete a folder and create a new folder to sync (using the symform control web interface), however, I am left with .symform folders on my NAS which I no longer require.
When I log on as Admin try to delete the folder and I cannot, says only the [SERVERNAME]\admin can delete the file. I am logged in as admin.
Can you please advise how I delete these folders, my NAS is mirroring the a new folder, will it delete these .symform folders following the successful mirror?
Thanks,
newowner.
rascalli
Easy as a breeze
Re: Delete .symform folders.
Post by rascalli »
did you try to login with putty or winscp ?
TS-419P , 4x 1.5TB HDD's
Installed apps :
* Sickbeard
* CouchpotatoServer
* NZBGet
* Spotweb
* Zenphoto
* Transmission
Return to “Symform”
