OSX Sierra and Spotlight indexing
Questions about using NAS on Mac OS.
davebtc
First post
Post by davebtc »
I'm having an issue with two iMacs on Sierra (one on 10.12.3, one on 10.12.1), where they cannot index the network share (connected through AFP). In terminal, if I do "mdutil /Volumes/name -i on" it just says "indexing disabled". I have another iMac that is on El Cap, which is able to index the share.
Any ideas? Anyone out there with Sierra that can test? Thanks!
aktivomat
Re: OSX Sierra and Spotlight indexing
Post by aktivomat »
I'm having the same problem since upgrading to Sierra. It seems that Sierra is the problem: https://apple.stackexchange.com/questio ... ng-anymore
Or did you find a solution?
Return to “Mac OS”
