Qnap ts 419 p II
we are not seeing any qnap shared file via wifi on mac finder. if we connect the lan cable: then we see the files.
thanks for your help
regards
m
mac finder not seeing qnap in network
Re: mac finder not seeing qnap in network
connect lan cable to qnap or router ?
- schumaku
Typical issues with el crapo WiFi routers not being fully transparent between WiFi and the switched LAN. Some might have a control to block WiFi<->LAN access, only permitting Internet. Some block IP Broadcast and/or IP Multicast, too - this is what is causing thee issues.
What brilliant router make, model, and firmware are we facing here?
