Error: Cannot connect to device. Please check if the device and your computer are on the same subnet.
Hi. Connection issue. I changed my Wifi Network ID and my qnap is wired directly to the wireless router. I notice this error message when I try to log in. I can not access my mapped drives to the NAS. I tried a reboot on the NAS but doesn't work. Help and thanks!
Re: Error: Cannot connect to device. Please check if the device and your computer are on the same subnet.
more info about the NAS, the client and configuration please
otherwise changing the name of the wifi should have zilch effect on NAS connection
- Don
Agreed. Wireless name has nothing to do with a hard wired connection.
Do you have in System->Security->Allow/Deny List allow connections from the list only set ip adressess? Try set the "Allow all connections"
- OneCD
It’s been 3 years. The OP has moved-on with their life.
* topic locked *
* topic locked *
