For a little while now, is sometimes have issues when trying to connect to a share on my Mac. When I click on my QNAP in de sidebar of the Finder (both AFP & SMB are visible), the QNAP suddenly disappears. I am still able to connect manually, but bonjour won't see the QNAP for a little while. If I manually disable and re-enable bonjour on the QNAP, the QNAP would reappear in the finder (or I just wait long enough, and the QNAP reappears all by itselfs).
Other bonjour broadcasted devices would still appear (in for example bonjour browser), so the issue seems to be the QNAP (TS-453B) with the latest OS.
Anyone else experiencing the same issues?
Bonjour issues
Re: Bonjour issues
This is actually getting pretty annoying... it happens 1 out of 3 times I guess... Is there a place on the forum I can submit bugs?
- OneCD
Re: Bonjour issues
No, bugs have to be submitted direct to QNAP as the community can only do so much.owentje wrote:Is there a place on the forum I can submit bugs?
