Just installed a 672XT and set it up as a static volume.
Populated it with my media files (photos and videos) made a folder structure.
All as Admin.
Added a few users, made sure they had privileges, even made one an administrator.
But no one except the Admin can access the files either in the web portal, or when f=trying to connect via the Qfinderpro app.
Firmware 4.4.0.0931
Thanks in advance.
Permission denied problems
- mdelrossi
TVS-672XT 4.4.0.0931 RAID 5 Static volume 4X Iron Wolf Seagate 10TB
Re: Permission denied problems
how about SMB mounts ?
file station and qfinder should only be used on occasion
- mdelrossi
yup, no luck using "connect to server" in the finder, either
what is the status of your access based enumeration ? (click on properties in "shared folders" towards the bottom)
- mdelrossi
Welp, When in doubt restart.
All is working as it should.
thanks for the help.
I have the same problem. Qnap share mounted via smb but I get permission denied when mounted as afp. doesn't matter if I mount as guest or registered user. Both guest and registered user have write permissions in file station. Looking at perms in terminal I get
drwx------ 1 zebee staff 16384 14 Aug 18:48 Video
I am the user zebee so theory says I should be able to write to that directory but I can't. IF i connect as admin it works, even thought the permissions in terminal are the same.
- PIRATA!
I know this is an old thread, but has anyone solved this?
I can't access several folders using other users rather than the admin one, and all of them have administrator privileges and accesso RW to those folders.
What can be done?
Thank you.
What can be done?
Thank you.
QNAP TS-251+ with 2x Seagate IronWolf 4Tb (ST4000VN008)
Could someone fix this issue?
open a ticket..nobody here can do anything about it
thread marked for closure for repeated necroposting
