Mac Pro 2013 10Gbe Problem
Questions about using NAS on Mac OS.
bfeagle
Post by bfeagle »
This is for a single-user, video production environment. Is the Mac Pro, late 2013, built-in ethernet connections really 10Gb? Everywhere I read says that's the spec. But I see no one using it that way. All of the info I find here shows you guys using TB2 to 10Gbe or external chassis adaptors.
The reason I ask is I have just received a TS-932PX to replace my old Pegasus2 R4. I put a 10Gtek transceiver to RJ45 in the QNAP and connected it directly to my Mac Pro. I can only get 100Mbs writes and 60Mbs reads. The NAS and Mac report a 10Gb connection. Tried jumbo frames at 9000 with little improvement. Now If I connect to the 932PX thru its 2.5Gb connection. Both NAS and Mac report a 1Gb connection. I get 110Mbs write and read.
The 932PX has 5 Seagate IronWolf 4TB drives in a RAID5 direct volume. No SSD cache yet.
What do you think? Do I need to get a TB2-10Gbe dongle to have a real 10Gb connection?
Bruce
dolbyman
Re: Mac Pro 2013 10Gbe Problem
Post by dolbyman »
I don't see any ethernet ports here
https://support.apple.com/kb/sp691?locale=en_CA
What 10Gtek adapter do you have ? The one that was just discussed in the German Qnap forum (was that you?) can only do 100/1000/10000Mbit, but not 2.5 or 5 Gbit
*edit* .. poster in the German forum had a 332X and a QSW-1105T.. so not you
bfeagle
Post by bfeagle »
A Mac Pro. Not a MacBook Pro
https://everymac.com/systems/apple/mac_ ... specs.html
It was not me on the other forum.
dolbyman
Post by dolbyman »
On the linked Website it says 1GbE not 10GbE
Screenshot_2021-04-09 Mac Pro Eight Core 3 0 (Late 2013) Specs (Late 2013, MQGG2LL A , MacPro6,1, A1481, 2630) EveryMac com.png
same on the official apple site
https://support.apple.com/kb/sp697?locale=en_CA
OneCD
Post by OneCD »
Agree: looks like 10GbE wasn't included until 2019: https://everymac.com/systems/by_capabil ... ernet.html
bfeagle
Post by bfeagle »
"Head Slap!"
Boy, Have been reading that wrong. Just now in the shower, I realized that was probably the case. Thanks for the confirmation.
I'll go and find myself a recommended adaptor and get back to work.
B
Bob Zelin
Experience counts
Contact:
Post by Bob Zelin »
Hi Bruce -
you will have nothing but disappointment. Do they even still make the TS-932PX ? What a piece of junk.
This is 2021. While I would have recommended the TS-h886 (which requires the optional 10G card QNAP QXG-10G1T) which is a 6 bay, you might
be able to get away with the TS-h686, which is a 4 bay (and yes, needs the QXG-10G1T).
But Thunderbolt 2 computers are dead, and if you are running a new operating system like macOS 10.11 Big Sur, you won't get any of the old 10G adapters to work like the Sonnet Twin 10G or Promise SanLink2. You are now "stuck" with the Sonnet Solo 10G T2, which is $199, and you will max out at 400 - 500 MB/sec over 10G with this adapter. Let me be clear. You could have an even larger QNAP (a 12 bay or 16 bay) and you are not exceeding these speeds with the Solo 10G T2.
Apple is doing everything they can to obsolete all the old Thunderbolt 2 hardware, so you won't get the old wonderful Thunderbolt 2 to 10G adapters to work with
a new operating system.
Get rid of that TS-932PX.
Bob Zelin
Bob Zelin / Rescue 1, Inc.
http://www.bobzelin.com
bokr71
Been there, done that
Post by bokr71 »
For those who are happy with your Mac Pro 2013s, there is an easy way to get 10GbE...
The Sonnet series of expansion boxes, TB2 or TB3, can easily accommodate the Sonnet Solo10G PCIe card, and that will get you full blown 10GbE on your Mac Pro. If you get a TB3 expansion box, you can use the Apple TB3-TB2 adapter.
Of course you can always setup the direct connection via Thunderbolt as well, it is actually faster than 10GbE. However, the latest beta of macOS screws that up entirely, as Thunderbolt Bridges are not working at the moment.
Apple: MS M1 Max 10c/32c/16c/64GB/2TB - MP 3.2GHz 16c/192GB/2TB/2xRadeon Pro - nMP 3.5GHz 6C/64GB/1TB/D700 - Echo Express 1TB Accelsior/4x500GB NVMe Sonnet/Sonnet Solo10G PCIe - MBP 13" 4c i7/16GB/512GB - MBP 14" M1 Pro/16GB/512GB - MB 12" 4c i7/16GB/512GB - MMI 6c i5/8GB/500GB - 2 x TC 3TB - HomePods - iPhones, iPads and Apple Watches...
Primary NAS: QNAP TVS-872XT 7x10TB + 2x512GB NVMe SSD. BackUp: Cloud iDrive - Locally QNAP TR-004 4x12TB
Network: ISP Gtateway - TP-Link Deco - QNAP QSW-M408-4C
Return to “Mac OS”
