SMB3 Issues after Qnap ARM->Intel switch?!
Questions about using NAS on Mac OS.
Rello
Post by Rello »
Hello all,
after 1 day of testing, I am lost.
I migrated from A TS-231P (ARM) to a TS-253A (Intel Cel.).
Putting the disks in, starting up, all nice and good.
But I cant connect via SMB3 from macOS anymore?!
  • Raspi or IP cam => Share ✅
  • macOS (old and current version) => Share ❌
  • manually setting the SMB-version to 2 on macOS ✅
  • putting the disks 1:1 back in the old Qnap ✅
  • activating AFP and connecting with macOS ✅
- in Qnap, the SMB versions are set v1 to v3 (IP cams still need the old v1)
- I reset /etc/config/smb.conf with the default config without success
- I reset all settings of the Qnap without success
do you have any other hint?
As other devices can connect and AFP also connects, a hardware or connection issue does not make sense to me.
Any idea appreciated
Rello
Re: SMB3 Issues after Qnap ARM->Intel switch?!
Post by Rello »
...keeping macOS on SMBv2 is not an option because Timemachine does not work then...
torch1
Know my way around
Post by torch1 »
Actually MacOS does very well with SMB2 (note that "SMB3" is actually a suite of dialects of the SMB2 protocol). Apple does not specify which version of SMB works with TM ( https://support.apple.com/guide/mac-hel ... h15139/mac ), but Apple's extensions to the SMB protocol require SMB2 or higher. https://wiki.samba.org/index.php/Config ... h_Mac_OS_X
As to OP's issue, I suggest:
- disable AFP - Big Sur (and maybe earlier?) does not officially support it anymore and Macs appear to get confused if both are enabled
- enable SMB2 (min) and SMB3 (max)
- enable Bonjour - Samba (and not AFP)
- mount the NAS from Finder > Go > Connect to server using the format smb://User@NAS where the User is the user on the NAS.
- if all fails, install Wireshark https://www.wireshark.org/ on a Mac, try to connect to your NAS, then filter on smb2 traffic
Rello
Post by Rello »
thank you for the reply.
I continued testing.
I switched the disk back to the old qnap to remain working.
Then I took a blank disk and comletely initialized the new Qnap from scratch.
Tada - SMB3 is working as expected.
conclusion: there seems to be some kind of config which does not work when taking over between the devices.
So now I am copying the data to the new. not as nice as switching the disks, but ok
Return to “Mac OS”
