Write only folder for Mac users
Questions about using NAS on Mac OS.
airhockey
First post
Post by airhockey »
So I have created a folder with write only permissions so Mac students can copy up homework to a folder but not modify it etc.. Everything works fine till they upload the file it says they cannot copy the file because they cannot read it. I really need to get this feature working any ideas?
OneCD
Re: Write only folder for Mac users
Post by OneCD »
Not-sure this can be done. If you provide write-access so they can upload files, you’re also giving them the ability to change existing files.
dolbyman
Post by dolbyman »
If you had a QuTS NAS you can setup WORM shares (Write Once Read Many)
OneCD
Post by OneCD »
Oh nice, I didn’t know QuTS supported WORM. :)
dolbyman
Post by dolbyman »
Tested it out for the German QNAP forum two weeks ago..works just as advertised
Return to “Mac OS”
