Ok so I have made some progress. Problem it, it makes a sub folder of the same folder I'm trying to sync.
Example:
I want to sync the "Multimedia" folders on two different Qnaps. (451U's)
One on I created a sync folder in BT, and pointed it to the Multimedia folder. Copied the read/write share code.
One Qnap #2 I did the manual add and pasted the share code from #1. It asks me where to put it. If I select the same "multimedia" folder, it creates a sub folder of the same name. If I select the /share root folder, it says BTSync doesnt have permission.
Anyone know how to sync two multimedia folders using this method?
Thanks in advance
Two Multi Media folders
- Iacopo
Re: Two Multi Media folders
Once you are prompt where to put it just select the folder that contains the Multimedia folder. It will say that the destination is not empty. Press ok and at this point it will sync the two folders. You will not lose data do not worry. It will sync both-ways the files.
