[QPKG] BitTorrent Sync now is avaiable
The 3rd party BitTorrent Sync app uses the P2P (peer-to-peer) protocol to synchronize an unlimited number of files (stored on the NAS) between your devices. Your data is not stored on a server in the cloud but is protected using private keys during file transmission.
John_Liou
Post by John_Liou »
[Description]
BitTorrent Sync uses the P2P (peer-to-peer) protocol to synchronize an unlimited number of files (stored on the NAS) between your devices. Your data is not stored on a server in the cloud but is protected using private keys during file transmission.
[Downloads Section]
ARM (x10/x12/x19 series) [TS-x10/ x12/ x19 / x19 P+ / x19P II series]
Intel x86Intel x86 [TS-x39/ x59/ 509/ 809/ 809U-RP/ SS-x39/ x59 Pro+/ x59 ProII/ TS-x79 Series]
[Release Information]
Version - 1.1.48
[Maintainer]
QNAP Systems, Inc.
merlinpimpim
Getting the hang of things
[QPKG] BitTorrent Sync update
Post by merlinpimpim »
Please,
I need a QPKG BitTorrent Sync update (to last 1.2.82 release) for use Encryption Read-Only Secret (not supported in current 1.1.82 version).
BitTorrent Sync Encryption Read-Only Secret that works with 1.2.82 (Windows/Android):
http://forum.bittorrent.com/topic/25823 ... t-api-key/
Thank you !
merlinpimpim
Re: [QPKG] BitTorrent Sync update
UP !
trendchiller
Easy as a breeze
Post by trendchiller »
a QPKG update would really be important as there are lots of problems with the actual qpkg btsync version:
BTW, I see that the clients you use are rather old. There were plenty of fixes since that time. One of things worth to try is 1.3 client, which has ability to connect over TCP in different networks (just in case if there is some issue with passing UDP thru VPN gateway).
see here:
http://forum.bittorrent.com/topic/28910 ... locations/
Teks
Contact:
Post by Teks »
Looking forward for BitTorrent Sync update, hope it's just around the corner. :)
trendchiller
Easy as a breeze
is the BTSync QPKG maintaines by QNAP or by BitTorrent ?
Does anyone know ?
Teks
Contact:
Post by Teks »
trendchiller wrote:is the BTSync QPKG maintaines by QNAP or by BitTorrent ?
Does anyone know ?
From the app description
Maintainer: QNAP Systems, Inc
trendchiller
Easy as a breeze
ok, so please QNAP, please ;-)
we'd be so happy about an upgrade ;-)
QNAPJames
QNAP Staff
Post by QNAPJames »
We have been working with BitTorrent Sync and the next update will be released by them soon, as well as future updates.
NAS: QNAP TS-464T4 Special Edition + Seagate IronWolf 125 3.84TB SATA SSD * 4 (RAID5)
Backup: QNAP TR-002 + Seagate IronWolf 10TB SATA HDD *2 (RAID0)
Networking: QNAP QSW-1108-8T 2.5GbE Network Switch
trendchiller
Easy as a breeze
James, that's really good news !
Thank you very much !
trendchiller
Easy as a breeze
if there's a testing QPKG, just let me know ;-)
merlinpimpim
QNAPJames wrote:We have been working with BitTorrent Sync and the next update will be released by them soon, as well as future updates.
Good news !
TS-870 Pro - i5-3570T CPU @ 2.30GHz - 16GB
QTS 4.3.4
TimRideout
Know my way around
Contact:
Post by TimRideout »
Hi all,
Bittorrent sync has just been updated to 1.3 for PC.
Is there an updated QPKG available?
Thanks!
T
maestro72x
Post by maestro72x »
Yes an update would be welcome.. I cannot get the current version to work at all..
maestro72x
Return to “BitTorrent Sync”
