Advanced Settings
Advanced Settings
Is there any way to set any of the more advanced settings for BTSync? I'm talking about sync_trash_ttl, folder_rescan_interval, that sort of thing. I've combed through all the files in the qpkg folder but haven't been able to find any reference to these. Are they hardcoded into the qpkg? Is there any way to modify them?
TS-439 Pro (replaced RAM with a 2GB module)
Firmware Version: 4.1.0 Build 20140612
Running: Optware (0.99.163), Python (2.7), BitTorrent Sync 1.3.106
Hardware: 4x 2TB Hitachi HDS722020ALA330 RAID 5
Re: Advanced Settings
I'm also interested in this. I uninstalled it some weeks ago because it was always scanning, as I have a lot of files. I would like to be able to set a bigger scan interval, as done in desktop version. Have you test the 2.2 version? Is it possible to set advanced properties?
- Iacopo
The link is from the official developer. It's for another issue but it will reply to your question.
http://help.getsync.com/hc/en-us/articl ... ng-on-NAS-
