I'd like to use Survallance Station with All ports closed on my router.
I don't want UPNP to open any ports. I'd like to use the myQNAPcloud to be used however I can't seem to get this to work. I can get the cameras to work on my network but not remotely on the phone app.
If anyone has gotten this to work can you tell me what domain pattern you used?
for example:
"acmenas.myQNAPcloud.com"
Thanks.
Survallance Station - All ports closed
- jimerb
CONFIGURATION
UNIT: TVS-873 (x3) - Running 4.4.2
UNIT: TS-873 (QuTS Hero) 5.0
WINDOWS 10/11
1GB Ethernet
WINDOWS 10/11
1GB Ethernet
- storageman
Re: Survallance Station - All ports closed
Get what to work?
Myqnapcloud
VMobile
QManage
Myqnapcloud
VMobile
QManage
- jimerb
vmobile using myqnapcloud domain with no ports open.
I want to use the myqnapcloud service to view my cameras without having to punch a hole in my firewall.
CONFIGURATION
WINDOWS 10/11
1GB Ethernet
WINDOWS 10/11
1GB Ethernet
- storageman
Does all this work?
https://www.qnap.com/en-us/how-to/tutor ... nage-a-nas
and acmenas.myQNAPcloud.com resolves to your public internet IP address (whatsmyip)
Does this help?
viewtopic.php?t=120352
Does this help?
- jimerb
QMobile doesn't have the signin with QID option. When I try using the myqunapcloud.com domain name it doesnt' work.
CONFIGURATION
WINDOWS 10/11
1GB Ethernet
WINDOWS 10/11
1GB Ethernet
- schumaku
Unless i' very wrong, Surveillance Station does not support Cloud Link access - only direct access on the LAN or on the WAN IP address with port forwardings in place.
Yeah, i raised a ticket about this before - would really like to see it support Cloudlink, which it currently does not.
