Block Remote Access To NAS
Hello, if I type in my public ip and the port to my nas, I can get the log in page of my nas. How do I block this so it can only be accessed on the lan. For my usage, I dont need to access it outside of my network. qnapcloud and cloud link were turned off but I can still access it from my phone's internet (not on wifi).
Re: Block Remote Access To NAS
don't forward any ports from the router to your nas ... also make sure you disable upnp on the router so devices cannot request their own port forwards
hi thanks. I already did disable upnp on my linksys router and no ports are fowarded but i can still access it from the public ip on my phone.. I will reboot everything and see what happens
- Don
If you can access it from the internet then there are ports forwarded.
Thanks guys. I had to reboot the router and nas. Everything is good now. I never had any ports fowarded in the router but upnp was enabled which I disabled. I guess enabling the qnapcloud features in the nas will re enable the access? Not that I need to but just curious.
well you either want access or not..but a vpn would make it more secure
