So my nas was connected to a unmanaged switch which in turn was connected to my ee router. Setup went fine and it all worked as it should.
I recently changed the switch to a HP Procurve 1810g-24 which was set to factory defaults so in theory should work but in practice it stopped the mycloud from working and the nas could no longer see the upnp on the router, if i go into the router and manually configure ports it will work but why should the switch stop this feature from working. The switch has no CLI just a web based gui.
Any thoughts or ideas would be appreciated before i buy another unmanaged switch.
Upnp auto config not working after changing switch
- storageman
Re: Upnp auto config not working after changing switch
Unmanaged
SMART/Web-based
Managed
So maybe the Procure is blocking ports?
Check it.
SMART/Web-based
Managed
Check it.
