How to disable qsync window on start-up
Hi
How can I disable to show up qsync window when computer start up. I tried all setting and din't find the option.. Anyone can help please
- storageman
Re: How to disable qsync window on start-up
Startup settings where it says II Personal
https://www.qnap.com/en-us/how-to/tutor ... rs-and-nas
Hi
Thanks for reply.. But my question was how to disable that window to show up when computer start up. I want the qsync launch at computer strat up but I just don’t want to be bothered with the window everytime I start the computer. Is there any option to disable the window to be open with “qsync launch at start up” on?
II Pesonal says to disable qsync at startup which disable also syncing with qnap
- storageman
Thanks again for the reply.. I wish to say that it works but I just can't find proper shortcut which is open at start up. I have changed shortcut on main screen, I have even change the shortcut in program menu but the window still appear when windows start. Any idea where is the shortcut I need to change to get rid of the window at start up?
- storageman
Ifconfig or startup folder should tell you where.
The startup folder is empty and the startup program pointing on application and not shortcut
- storageman
They are shortcuts in task manager, startup.
Can't you create your own shortcut, point it at qsync and add to startup , like.
start /min "C:\program files\qsync"
I'm not quite sure how to do it.. I can create a shortcut in start menu - startup and disable it in task manager - startup but I'm not sure if I can do it and if it won't affect synchronization. I don't know how to make new or edit path in taskmanager - startup programs. Don't really see that option there anywhere
- storageman
Try creating a batch file "MyQsync.bat" with "start /min "C:\program files\qsync" in it and put in task manager, startup.
As long as the program is loaded shouldn't matter if min or maximized.
The problem is that I don't know how to put a file in task manager - startup. There isn't any add option. Sorry for that. I worked on iMac for 2 years and unfortunately I had to go back to windows (guess I must find a way to go back to mac). I forgot most of the things on windows now
- storageman
Thanks for help.. That didn’t help either. However I asked qnap support and they categorized it as bug and, as far as they said, they put it in the queue for analysis. Wander why no one else noticed that.. Or is everybody just closing that window everytime they turn their computer on...
