Aruba and Qnap don't get along
Post your questions about myQNAPcloud service here.
Consulmac
Post by Consulmac » Sun Apr 21, 2019 1:44 am
I have forwarded the necessary ports on Aruba Cloud interface, the DLNA/UPNP is activated but the Qnap cannot automatically forward the necessary ports for connection.
here is my diagnostic if anyone could help I am just about to switch my client's network to Ubiquiti since Aruba is too much too handle...
------ NAT PMP Diagnostics ------
initnatpmp() returned 0 (SUCCESS)
using gateway : 192.168.0.1
sendpublicaddressrequest returned 2 (SUCCESS)
readnatpmpresponseorretry returned -7 (FAILED)
------ UPnP Diagnostics ------
upnpc : miniupnpc library test client. (c) 2006-2011 Thomas Bernard
Go to http://miniupnp.free.fr/ or http://miniupnp.tuxfamily.org/
for more information.
List of UPNP devices found on the network :
desc: http://192.168.0.118:32469/DeviceDescription.xml
st: upnp:rootdevice
desc: http://192.168.0.118:8200/rootDesc.xml
st: upnp:rootdevice
desc: http://192.168.0.118:8080/upnpd/a821c82fa4.xml
st: upnp:rootdevice
UPnP device found. Is it an IGD ? : http://192.168.0.118:32469/
Trying to continue anyway
Local LAN ip address : 192.168.0.118
GetConnectionTypeInfo failed.
Status : , uptime=72s, LastConnectionError :
Time started : Sat Apr 20 13:35:41 2019
MaxBitRateDown : 0 bps MaxBitRateUp 0 bps
GetExternalIPAddress() returned -3
GetExternalIPAddress failed.
GetGenericPortMappingEntry() returned -3 ((null))
INFO: No any UPnP port mapping entry is found.
P3R
Re: Aruba and Qnap don't get along
Post by P3R » Mon Apr 22, 2019 6:27 am
...the DLNA/UPNP is activated but the Qnap cannot automatically forward the necessary ports for connection.
I wouldn't use UPnP at all and definitely not for a client.
Consulmac
Post by Consulmac » Fri May 03, 2019 3:54 am
UPNP/DLNA is not working anyhow so I got the ports to forward to the QNAP but now my issue is that I can't open OwnCloud from WAN. What port does use OwnCloud usually?
Return to “myQNAPcloud service”
