how can i disable to show up myQNAPCloud connect window (the auto start-up of application) when computer start up!? I tried all setting and didn't find the option.. Anyone can help me? Please.
Thank you.
How to disable myQNAPCloud Connect window on start-up
Re: How to disable myQNAPCloud Connect window on start-up
if there is no such option in the settings:
- disable the autostart for the program
- ask qnap via ticket to add an option to disable the splashscreen
- use plain vpn (e.g. windows buildin) to connect to your vpn
This is the solution:
You must disable the relative task scheduled process from task scheduler of Windows. See the picture attached to this post:
Greetings
Greetings
