Just setup myqnapcloud service. I am unable to reach my qnap using DDNS.
On the overview page under "Auto Router Configuration" there is a green check beside "status" and a red X beside "Web Connectivity."
Under "Internet Address" there is a green check beside status, and an amber exclamation "not installed" beside ssl certificate.
Can't reach myqnapcloud using DDNS
Qnap TS-251 4.5.1 2-wd 4 tb red (8 tb total Setup as JBOD)
Qnap 212p 4.3.3 2-wd red 4 tb (8 tb total Setup as JBOD)
4 PC Users with Laptops
1 Mac User with Laptop
Re: Can't reach myqnapcloud using DDNS
I can access it if I go to www.myqnapcloud.com and login.
